Changing Front SHocks
Old Aug 9, 2009 | 03:41 PM
leeboy's Avatar
I was wondering if i had to jack up the truck and pull the front tires off to do this? Any other tricky parts i may run into?
Old Aug 9, 2009 | 05:50 PM
nickg's Avatar
no need to jack anything up. remove center nut on tripod tower(upper shock nut) then pull the 3 nuts that around it, remove tower, remove lower bolt, the nut has an arm attached to it so there is no need to put a wrench back there to hold the nut. reach in thru the top and pull the shock out, replace in reverse order. drivers side is a pain, I unhook the tripod tower and lay it on its side and fish the shock out.
pass side you need to remove the air box to acess the shock tower, suggest you start on this side first, as its easier to do.
lower bolts will need to be super tightened as the metal is hard to compress tightly around the lower shock mount, symptoms of too loose is a thumping noise felt in the floor boards
Old Aug 10, 2009 | 01:16 AM
leeboy's Avatar
Cool...... Thanks Nickg ..... Couple hours tops?
Old Aug 10, 2009 | 08:10 AM
nickg's Avatar
Takes 15mins a side if nothing is rusted together
Old Aug 10, 2009 | 04:23 PM
CORed's Avatar
Originally Posted by nickg
...lower bolts will need to be super tightened as the metal is hard to compress tightly around the lower shock mount, symptoms of too loose is a thumping noise felt in the floor boards
I can echo this... but also suggest squeezing (in a press perhaps) the metal sleeve on the lower end of the shock so the bolt has to be hammered thru it when re-installed. This is what I did and it kept the thumping noise away for years on my 5100s.
And if you have a long extension (probably end to end) for your sockets, it makes the job easier.
whosdunit
Jan 11, 2017 01:54 AM
BibBubba
Apr 10, 2011 07:48 PM
RDM16CTD
19
Jul 31, 2009 06:07 AM
leeboy
Jun 26, 2009 12:56 AM
Beavermike
Aug 27, 2005 12:53 AM
