Changing Front shocks
Old Jun 25, 2009 | 06:04 PM
leeboy's Avatar
Hi, could someone tell me the best way to change the front shocks? (and the easiest) Thanks gang....
Old Jun 25, 2009 | 06:17 PM
Kenny D's Avatar
remove the little (tri pod) they bolt to and move it to the side take the shocks right out the top thorugh the hood opening. Its actually real easy just did mine. Good luck
Old Jun 25, 2009 | 07:25 PM
leeboy's Avatar
Sounds good, thanks!
Old Jun 26, 2009 | 12:56 AM
Ruralmedic's Avatar
Just did mine 2 days ago, and as previously stated, remove the top towers and they pull right out through the engine compartment. A trick I learned from searching on here was to jack the front axle up as far as you could and place two jack stands on the frame, then slowly lower the axle so the shock is fully extended. Made change out a breeze. PB Blaster on the fastner hardware helped also.
whosdunit
Jan 11, 2017 01:54 AM
BibBubba
Apr 10, 2011 07:48 PM
leeboy
Aug 10, 2009 04:23 PM
RDM16CTD
19
Jul 31, 2009 06:07 AM
Beavermike
Aug 27, 2005 12:53 AM
