CEL light on while going down ramp
Old Mar 18, 2012 | 11:05 PM
JARHEAD's Avatar
Had to back truck and 30 ft trailer down the ramp and onto the ferry this evening. Guessing maybe 7-8% grade. Maybe more. Backing down went really slow. Once on boat notices the CEL was on. Tried to pull codes but I think the edge juice/attitude prevents it. They would not run. Any idea what would throw a code doing that? I figure it has to be something with oil pressure.
Old Mar 19, 2012 | 12:26 AM
rebal's Avatar
trans can trip cel maybe it is related to that
Old Mar 19, 2012 | 07:17 PM
rickf's Avatar
You would have to be almost empty on oil for that to be a problem. 8% is not all that much of a grade. It always feels worse than it is, especially going backwards. You can disconnect the batteries for a half hour or more and then reconnect and that should wipe out any codes that were set. I would disconnect the Edge and pull the codes so you know what it is just in case it is important. Hopefully it is not related to your fuel pressure issue from your other post. That would be why I would want to see it.
Old Mar 19, 2012 | 07:33 PM
JARHEAD's Avatar
Pulled the code and it is a 0500. So not related. The light was gone tho morning already. Maybe just one of those things....
Old Mar 19, 2012 | 08:09 PM
Busboy's Avatar
0500 is a skim key I think. Do you have any other keys on there that could interfere with the transponder encoded key for the truck. perhaps the angle moved the other key too close.
Old Mar 24, 2012 | 06:24 PM
iah145ca's Avatar
P0500 Vehicle Speed Sensor A
Old Mar 24, 2012 | 07:37 PM
rickf's Avatar
A 500 depends on your reference material. Some say sensor 1, some say sensor A, some say no speed sensor reading. no matter, it is a speed sensor code.
Rick
Old Mar 24, 2012 | 08:47 PM
Busboy's Avatar
Oops 0513 is the skim key code, sorry.
JARHEAD
Jun 16, 2012 11:50 AM
MrSuzuki
Jun 16, 2009 12:23 AM
boaterman
Oct 15, 2008 10:44 AM
Hillbilly Delux
Mar 20, 2008 05:01 PM
The Boss Hog
Mar 18, 2003 01:19 PM
