catalytic converter
Old Feb 11, 2004 | 06:31 PM
herb's Avatar
catalytic converter
talked to a man today with a 99 cummins who swears up and down that after he removed his catalytic converter (ran straigt pipes) his fuel mileage increased 8 mpg and said he rewad somewhere on a dodge forum that someone else who had done the same thing had passed a state emissions check.
can this be right?
Old Feb 11, 2004 | 06:43 PM
travjrath's Avatar
catalytic?????? my 98.5 and every 24 valve that worked with does not have a cat , they have a resonater (a sound killing device) however i dont know about the CA models. As far as the mileage goes ...my 98.5 got worse (.5 -1 mpg) all of the other trucks (15 or so) that i put a straight pipe in didn't change the milage at all ... but they sounded good !!!!
Old Feb 11, 2004 | 06:58 PM
herb's Avatar
what is the advantage of going 4" all the way thru? will it make it louder in the cab?
Old Feb 11, 2004 | 07:04 PM
travjrath's Avatar
on my truck at highway speed (65 -70 ) i noticed much less noise in cab with 4in straight pipes , it was louder at 1600rpm or so , but that was good for blasting someone next to you
Old Feb 11, 2004 | 07:20 PM
Scubasteve's Avatar
My 95 and my 01 has a catalytic convert on it of some sort. When you look inside it has that honey comb stuff inside. Thats what I always thought it was anyways
I was wrong once before but found out I was mistaken. hehe
Jason
Old Feb 11, 2004 | 07:31 PM
travjrath's Avatar
i dont know how many versions of the ram are out there the trucks i spoke of are from texas , most of my 12 valve buddies had cat's ... but none of the 24v's did may just be diff versions , i dunno
Old Feb 11, 2004 | 07:41 PM
billg's Avatar
I just had mine replaced with a 4" silverline system and mine had a resonater (looks like a small muffler ahead of the big muffler). Here is a write-up of this (it is in the 5th paragraph):
http://www.bluechipdiesel.com/brief-education.htm
Hope this helps
RamWheelsBy4
17
Aug 25, 2004 10:24 PM
Cumminsdude
Jul 27, 2003 10:09 PM
Hummin Cummins
Apr 10, 2003 10:29 PM
mymaur
Dec 26, 2002 12:08 PM
TIM-D-FARMER
Nov 4, 2002 11:00 AM
