Can't get injectors out
Old Aug 30, 2005 | 12:12 PM
01-24v's Avatar
Question Can't get injectors out
Gauges and injectors came in yesterday. Installed the gauges, started on the injectors and I can't get them to even budge.
Whats the trick here? I used the air plenum bolt method described in a guide I found on here and they wont lift out.
Realized I might bend one of those bolts so I went down to the hardware store and bought a couple more, ripped the head off one and still no luck
2001 24v
Old Aug 30, 2005 | 12:16 PM
RustyJC's Avatar
Have you loosened the injector line hold-downs, the injector cross-tube nuts on the driver's side of the cylinder head and pulled the fuel cross-tubes back while popping the injectors out? Did you remove the injector hold-down bars?
Rusty
Old Aug 30, 2005 | 12:28 PM
storx's Avatar
if you slightly loosen the injector hold down tubes and pull them away from the the injector a little the injector should come out liek butter..........if its hard to take them out your doing it wrong.........all the cummins i pulled injectors would come out so easy when you took off the tubes....
Old Aug 30, 2005 | 12:59 PM
Mike D's Avatar
http://www.lib.uaa.alaska.edu/~tibor...structions.pdf
Just in case you didn't have good instructions.
Old Aug 30, 2005 | 08:47 PM
01-24v's Avatar
Thanks Mike I already had good instructions
What goods a guide if you don't read it huh?
Injectors are in now
Old Aug 31, 2005 | 08:13 AM
RustyJC's Avatar
And the problem was..... (C'mon - remember, confession is good for the soul! )
Seriously, if you'll post how the problem was resolved, the solution can help someone else who is reading these forums.
Rusty
Old Aug 31, 2005 | 04:38 PM
01-24v's Avatar
It was the fuel tubes.
Old Aug 31, 2005 | 05:02 PM
mikmaze's Avatar
well get er bled and fired up and give us an update. pics smoke ya know.... this forum feels it is worthless without pics........
Old Aug 31, 2005 | 09:58 PM
01-24v's Avatar
I haven't taken any pics of it yet. Owned it for about 2 weeks and it's still on
auto trader
Definitely saw a nice improvement in power. Not sure about peak numbers but it certainly felt like it leveled out the power curve, turbo spools up alot faster and the bottom end is a hell of alot stronger. No problems breaking the tires loose now even with the LSD.
Haven't noticed anymore smoke then normal, a little black poof at start up but it did that before I put in the injectors.
It did take about 3 cycles to get it started up for the first time, lots of smoke then and it sounded like a cammed v8 for the first couple of minutes at idle
After driving it around all day, it seems smoother then before and even a little quiter. Like them so far.
Bosch 275/300 I got off ebay for $280
Haven't decided on which exhaust to get yet, probably just a 4" and the sneaker series muffler from source automotive. Intake will be a bhaf and homemade intake tube and I'll probably leave the truck alone after that. Will need to save up for some tranny mods before I get to crazy
Old Aug 31, 2005 | 10:37 PM
jrs_dodge_diesel's Avatar
Hope you have a pyro guage so you don't melt a piston.
Totallyrad
Jul 19, 2011 07:41 AM
snowmanx
May 23, 2010 09:18 PM
KRB
May 20, 2007 06:20 PM
BIGOKIE
Jul 21, 2004 05:53 PM
