Can the KDP happen on a 2001?
Old Jul 2, 2010 | 07:26 PM
WHISTLINTURBO's Avatar
Like title says. I have the cover off now because of oil leaks that i've had for years and finally decided to fix. Do I need to tab the dowel in my 2001?
Old Jul 2, 2010 | 07:35 PM
Dr. Evil's Avatar
It is a possibility. It depends if you got the updated cover or not. The only way to know is to pull the cover off and check.
There was a post here where a guy with a 2002 dropped the dowel pin. It was backed up by a repair invoice from Dodge.
They well the KDP repair kits for both 12V and 24V's.
Old Jul 3, 2010 | 02:04 PM
2002-5.9's Avatar
If you have the cover off the pin is right there to the left of the pump gear. Tab it now and sleep easy. Try here for some pics:
https://www.dieseltruckresource.com/...?searchid=9527
Old Jul 3, 2010 | 02:21 PM
Well there is a big lip from the bolt to where the dowel is. And the dowel is set in there quite a ways. I think it must be the updated gearcase that was not reamed all the way through.
SILVER GUS
Jan 18, 2011 01:28 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
TriSum
Feb 9, 2008 08:35 PM
beandrew
17
Feb 6, 2006 09:43 PM
bigfoot
Aug 14, 2004 02:22 PM
