Bypassing oil sensor
Old Oct 13, 2009 | 07:12 PM
mutang460's Avatar
I've been reading posts after posts and have found a crap load of info, but not what I want to know... Has anyone put in a machanical oil pressure guage and just bypassed the oil pressure sensor, I know that is the problem because i check the pressure and its good but my guage is reading nothing nada... $12 guage or $100 sensor.... I just need a answer if you can or not will my truck shut down if i dont replace the sensor?
2001.5 Ram 3500 4x4 24v
Old Oct 13, 2009 | 09:39 PM
dozer12216's Avatar
To my knowledge it will not quit. I futher beleive your sensor is really nothing more then a pressure switch with fancy connector. The ECM looks for switch to go open and generates a gauge movement that satsifies the driver.
Old Oct 13, 2009 | 11:42 PM
bentwings's Avatar
I have a mechanical gage in my truck. The only real problem is that the oil line is pretty long and too small diameter. It take a long time to show oil pressure in the winter.
I'd suggest using a 1/4 in brake line up to the dash opening where ever you drill it.. Put a rubber gromet inthe hole and use a #4 braided line to the gage. It still will be a little sluggish in the winter but better than the puny line that comes with the gage.
The truck will run fine with the sender connected but you will probably get a check engine warning.
Old Oct 14, 2009 | 11:25 AM
mutang460's Avatar
Ok, so i just have to look at a light on my cluster no problem... Mechanical guage it is.
Thanks
Old Oct 15, 2009 | 05:21 AM
dozer12216's Avatar
Don't worry about slow response. You know as soon as the needle moves, you are good to go. Route small line away from heat.
Bruce M
Dec 17, 2013 02:59 PM
cincydiesel
Jan 27, 2008 02:12 PM
Bham Ram
Mar 29, 2007 05:00 PM
robert78.5
Dec 26, 2006 10:52 PM
adidasman23
Dec 22, 2006 02:43 PM
