Brake warning lights on dash
Old Aug 19, 2017 | 04:18 PM
Lunds Ram's Avatar
So the warning lights on the dash came on in my 2000. It's the abs light and brake lights. I think it's telling me that my and module is done. They come on above 30 mph, but the truck still stops great. I can't get any codes from the abs. Any insight as to what's possibly going on?
Old Aug 20, 2017 | 12:11 PM
Lunds Ram's Avatar
Ok, I figured it out. I had my waste gate bypassed and the truck was throwing an overboost code. Hooked it back up and the lights never came back on. Downfall is, I went from 28 psi to 20 psi of boost. I need a tuner.
Old Aug 20, 2017 | 02:39 PM
Desert5600's Avatar
I like my Smarty. Different programs, better mileage, boost fooler, code reader/resetter, tire diameter adjuster and three cylinder high idle warmup. Get a boost elbow with it.
It recognizes the stock computer programming if you need to go back for any reason. I had my stock software updated at Dodge beforehand in case it made a difference. Ran better than before the update...and much better after the Smarty.
Old Aug 20, 2017 | 03:02 PM
Lunds Ram's Avatar
I was thinking of getting a smarty. It's a bit cheaper than edge juiced, but was also considering the edge ez, or edge comp.
Old Aug 20, 2017 | 10:15 PM
SIXSLUG's Avatar
Not sure why your abs and brake light would come on in relation to an over boost issue...
Mine come on if I drive thru deeper mud or water, not really any relation to engine boost...
Old Aug 21, 2017 | 02:22 PM
Lunds Ram's Avatar
It threw me off too. But all I did was plug the waste gate back in and the lights never came on while I was driving. I'll play with it some and see what it does.
Old Aug 21, 2017 | 10:37 PM
SIXSLUG's Avatar
Weird,,,
Old Aug 22, 2017 | 12:40 PM
Lunds Ram's Avatar
The only thing I can think of is the tone ring or sensor had an issue and it coincidently resolved it's self when I plugged the wage gate back in.
NoSparkplugs
17
May 17, 2009 10:36 PM
polaris800sp
Nov 13, 2008 05:35 PM
jj3500
Jul 5, 2008 11:20 AM
CHarlan
Aug 6, 2003 08:40 PM
