Boost Valve Assembly?????
Old Apr 11, 2009 | 12:28 PM
1fstdsl's Avatar
I lost lock-up in my truck to I pulled the valve body and found the boost valve parts in the bottom of the pan. Does anybody know how this goes back together?
There is a valve, plug(spacer), spring and then the retainer. What order do these go in? Thanks
Old Apr 11, 2009 | 01:53 PM
Russ Roth's Avatar
The plug goes first then the valve, spring and retainer. Did the retainer break or did it come apart for some other reason?
Old Apr 11, 2009 | 02:23 PM
1fstdsl's Avatar
Thanks for the response, that was going to be my guess. The tabs on the retainer bent. Should I bend them back or fabricate a new one? I want to put it back together tonight and nobody has one in town.
Also, just to be sure which way does the valve go in? Thick end first? (only way I know how to describe it)
Old Apr 11, 2009 | 06:58 PM
Russ Roth's Avatar
I think I understand you and the thick end goes in first. The spring goes over the other end, I think. It's been a while since I have worked on one and I am looking at the picture in the manual. I think I would fab another retainer. I've heard of them doing that before and also breaking.
Old Apr 12, 2009 | 01:26 AM
1fstdsl's Avatar
It is back together and working fine, thanks.
Old Apr 12, 2009 | 02:47 PM
Russ Roth's Avatar
Good deal. That turned out cheap enough, didn't it?
Old Apr 12, 2009 | 05:20 PM
Fishin2Deep4U's Avatar
They make a heavy duty retainer. Mine broke once as well. Get the upgraded version and it'll never happen again.
Dave
Old Apr 12, 2009 | 08:09 PM
Russ Roth's Avatar
Dave,
Who makes those and where do you get them?
Old Apr 12, 2009 | 11:53 PM
Originally Posted by Russ Roth
Dave,
Most any trans shop and or trans supplier stocks them.
Dave
Old Apr 13, 2009 | 12:52 AM
Russ Roth's Avatar
Thanks.
jcarrillo
Jul 10, 2009 08:24 PM
rich
May 9, 2003 09:33 PM
reeldeahl
Apr 15, 2003 05:29 PM
