boost
Old Apr 7, 2008 | 01:39 PM
TOM R's Avatar
boost
fixed my boost leak, how much boost should I have with a stock turbo?
Old Apr 7, 2008 | 01:51 PM
offroad's Avatar
According to here:
http://www.dodgeram.org/tech/dsl/Facts/01ISBspecs.html
Looks like 20.8 psi for a non HO and 26 psi for an HO engine.
Old Apr 7, 2008 | 01:52 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Max should be around 20-21 lbs.
Old Apr 7, 2008 | 09:21 PM
TOM R's Avatar
ok thanks, i am getting like 20 max figured it would be more
Old Apr 8, 2008 | 01:17 AM
glenn-k's Avatar
BHAF adds some - 4 inch straight exhaust adds some - Edge EZ adds some (thats the chip I have) I have about 27 psi at WOT under load.
I read somewhere you gain about 1 lb boost per 10 HP added. With the Edge there is a mod to the little elbow on the turbo to keep from setting off a code and fuel cutback for overboost.
Old Apr 8, 2008 | 10:35 AM
AK diesel dog's Avatar
Hey how did you find your boost leak?
Old Apr 8, 2008 | 11:39 AM
JPR Ram's Avatar
That's not quite right. The "Boost Elbow" is what controls the wastegate allowing the turbo to produce more boost. But the ECM will detect, via the MAP sensor, a higher amount of boost and it will set a code for "Over Boost Condition - Out of Range" (or something to that effect) and cause a "de-fueling situation. To combat this condition, the Edge, or Quadzilla, or Banks and etc. has a "Boost Fooler" that plugs in between the MAP sensor and the ECM. The purpose is to change the MAP signal to read within factory parameters before it gets to the ECM. So if the "Boost Elbow" is adjusted to allow 35 lbs of boost, and if the motor is making it, the MAP sensor will read 35 lbs of boost and send that signal to the Edge (or equivilant) which will send a lessor amount (maybe only 20 lbs) to the ECM.
Old Apr 9, 2008 | 10:01 AM
sixb's Avatar
Will a boost fooler with no chip of any kind allow you to boost past the factory setting of 20-21 without throwing codes? My truck is capable of 30+ but I no longer have the juice with attitude.
Old Apr 9, 2008 | 11:34 AM
JPR Ram's Avatar
Yes. You will need some way to adjust the wastegate and there are several companies that make a stand alone boost fooler. Quadzilla, BD Diesel, to name a few. Though, you may not see boost levelas as high as you did with the Juice, because you're not flowing as much fuel.
Old Apr 9, 2008 | 11:44 AM
sixb's Avatar
I don't have gauges yet, but when it's building boost it kinda hits a wall and you can feel it defuel. I'm hoping a boost fooler will get rid of that. I have a hybrid 60/14 rv275 and 4" exhaust so it should build some decent boost. Thanks.
HOHN
45
Oct 8, 2005 08:51 AM
triplenickel
Aug 23, 2005 04:01 PM
GTSDave
Jul 8, 2005 09:06 AM
MY WORLD
25
Dec 29, 2004 08:54 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
