Blow By
Old Oct 14, 2004 | 10:50 PM
hauliday's Avatar
Blow By
how much blow by is normal ????
I had removed that goffy cup that catches the blow by residue and put a hose on it anp put it about 4" below the A arm on the front end . I have noticed after the truck is at operating temp. i have some noticeable blow by . but having owned and operated several big trucks I know blow by is normal and i also noticed it depends on the brand oil oil that you run I am running schaffers in this truck and at last oil analsys everything was great then so i was wondering if this is normal or should i start looking for a replacement truck i was hoping to run this one for another year at this moment i have about 240,000 miles on it now
Old Oct 14, 2004 | 11:48 PM
Haulin_in_Dixie's Avatar
My original engine always had a good amount of blowby, in the winter with some breezes I would see it drift past the nose of the truck. I used to worry about it a lot. The engine was in great shape and it pulled good. Some do this some don't.
The vacuum pump can also add to the blowby, a vacuum leak can cause it. The exhaust of the vacuum pump is to the crankcase. You will find that it depends on the humidity on how much you see. If I hold my hand over the breather on my engine I can feel a lot of it coming out, but cannot see it.
Unless you have the oil problems along with it, I would not worry about it.
Old Oct 15, 2004 | 12:02 AM
Dr. Evil's Avatar
Have a look at this thread.....there is directions by Infidel that tells how to build a blow-by tester:
https://www.dieseltruckresource.com/...threadid=52217
Old Oct 15, 2004 | 08:25 PM
hauliday's Avatar
thanks for the info
cfm3110
Mar 12, 2003 08:34 PM
DEZLPWR
Feb 14, 2003 08:40 PM
Iron Horse
Feb 12, 2003 10:51 AM
latitud_rt
Jan 1, 2003 12:41 PM
