Block cracking number
Old Feb 25, 2003 | 01:01 PM
  #46
DEZLPWR's Avatar
Re:Block cracking number
[quote author=Dave65 link=board=4;threadid=9428;start=30#108937 date=1046196391]
My truck was built here in the states,does that mean I need to worry?
[/quote]
Yes, you still need to "worry", although I am not... My '99 was built in St. Louis, MO and I have the 53 block. I however, sleep very well at night. There is nothing to worry about until it cracks! Until then, there is absolutely NOTHING you can do to keep it from cracking.... :'( :'(
Just enjoy life and your CTD. ;D ;D
Old Feb 25, 2003 | 01:17 PM
  #47
Dave65's Avatar
I don't know if I have the #53 or not,I do know it has 101,000 very hard towing miles on it.But I am going to check it to see.<br>Im afraid to look :
Old Feb 25, 2003 | 01:40 PM
  #48
dodgeman01's Avatar
[quote author=Dave65 link=board=4;threadid=9428;start=45#108958 date=1046200676]<br>I don't know if I have the #53 or not,I do know it has 101,000 very hard towing miles on it.But I am going to check it to see.<br>Im afraid to look :<br>[/quote]<br>I just never looked. I mean hey at 135k if it cracks it cracks.<br>DM01 [undecided]
Old Feb 25, 2003 | 03:16 PM
  #49
rich's Avatar
hell mine has a 158k on it and all its done is haul cattle or equipment since it was born. its still going strong but we'll see when it gets good and bomb'd
Old Feb 26, 2003 | 08:29 AM
  #50
Tiny's Avatar
I was under my truck, and looked for the block number. What I came up with 14m73. Does this make sense? I am hoping for a Mexican block, but every now and then I get a strong whiff of anti-freeze. No steam on windshield, so I do not believe it is the heater core. Most of you have said the Mex. block is 6 digits, or am I even looking in the right spot? I am looking on the driver side, below the inj. pump, right around the P/S pump. Please advise, as I only have 11,000 miles left under warranty.
Old Mar 1, 2003 | 11:23 AM
  #51
Marine's Avatar
Veteran: Marine Corp
Mine cracked at 4500 miles.<br><br>Mike
Old Mar 1, 2003 | 09:45 PM
  #52
dingo's Avatar
I agree wit DEZLPWR ..... if it cracks it cracks.There are people with 53 blocks that do heavy haulin and their trucks have over 200k on them.. iN FACT JUST today I bought my first CTD with a 53 block. I didnt let it break thedeal... it is hard to find a good truck that has been taken care of.. just my input
Old Mar 3, 2003 | 03:43 PM
  #53
latitud_rt's Avatar
Am I looking in the correct place? My truck is a 2002, 2500. I understand the number is suppose to be on the drivers side just above the oil pan towards the front of the engine. Kinda in the area behind where the blow by bottle blows all the oil( i know down a bit from that). There is a engine harness about 1 inch in diameter attached to the block right in the way of the only numbers I see. From what I can tell, there are two rows of numbers. The top row is about 8 numbers (j144.....) the bottom row is three numbers (260). Are these the right numbers?<br><br>Thanks,<br><br>Tim
Old Mar 3, 2003 | 07:41 PM
  #54
Pit Bull's Avatar
[quote author=latitud_rt link=board=4;threadid=9428;start=45#111245 date=1046727816]<br>Am I looking in the correct place? My truck is a 2002, 2500. I understand the number is suppose to be on the drivers side just above the oil pan towards the front of the engine. Kinda in the area behind where the blow by bottle blows all the oil( i know down a bit from that). There is a engine harness about 1 inch in diameter attached to the block right in the way of the only numbers I see. From what I can tell, there are two rows of numbers. The top row is about 8 numbers (j144.....) the bottom row is three numbers (260). Are these the right numbers?<br><br>Thanks,<br><br>Tim<br>[/quote]<br><br>Tim you have a 2002 which means you have the 12mm thick HD block and will not have a problem. Yours should have a &quot;55&quot; or &quot;56&quot; where you are looking. But it sounds like you have a 2002 Mexican block which is the most HD block Cummins makes. Congrats. Hang on to that truck!!!
Old Mar 8, 2003 | 08:53 AM
  #55
Marine's Avatar
Mine has 55 in the block. Where is this one from? It is a replacement from my cracked one.<br><br>Mike
Old Mar 8, 2003 | 10:25 AM
  #56
Scotty's Avatar
Top's Younger Twin
Mine has a LARGE 53 on the block on the passenger side.
When I change the oil, I can see it everytime...so naturally I check for leakage along the area they are known to crack. So far so good.
Old Mar 8, 2003 | 02:36 PM
  #57
Dave65's Avatar
[quote author=CTD 359 link=board=4;threadid=9428;start=45#113248 date=1047140722]<br>Mine has a LARGE 53 on the block on the passenger side.<br>When I change the oil, I can see it everytime...so naturally I check for leakage along the area they are known to crack. So far so good.<br>[/quote]<br><br><br>What year is your truck CTD 359?<br><br>Just curious
Old Mar 8, 2003 | 05:44 PM
  #58
Scotty's Avatar
Top's Younger Twin
[quote author=Dave65 link=board=4;threadid=9428;start=45#113301 date=1047155812]<br>[quote author=CTD 359 link=board=4;threadid=9428;start=45#113248 date=1047140722]<br>Mine has a LARGE 53 on the block on the passenger side.<br>When I change the oil, I can see it everytime...so naturally I check for leakage along the area they are known to crack. So far so good.<br>[/quote]<br><br><br>What year is your truck CTD 359?<br><br>Just curious<br>[/quote]<br><br>2001<br>built in March of 2000
Old Mar 17, 2003 | 08:31 PM
  #59
Dave65's Avatar
I just checked mine today,warm outside so I figured be a good time and it has a big 53 on it
Old Mar 18, 2003 | 12:04 AM
  #60
Marine's Avatar
[quote author=Marine link=board=4;threadid=9428;start=45#113228 date=1047135211]<br>Mine has 55 in the block. Where is this one from? It is a replacement from my cracked one.<br><br>Mike<br>[/quote]<br><br>Does anybody know what the 55 is?<br><br>Mike
