BHAF Question
Old Oct 13, 2012 | 03:43 PM
SIXSLUG's Avatar
BHAF Question
So how long have you kept a BHAF filter?
Mine is a NAPA brand and I drilled it and installed my filter-minder off the stock air box. The filter minder hasn't budged and it works, I checked it.
The filter has been in use since 12/07 and is kinda gray and has never gotten wet.
Comments?
Old Oct 14, 2012 | 08:41 AM
67HotRod's Avatar
Mine has been on several years, never changed it...
Old Oct 14, 2012 | 11:32 AM
rebal's Avatar
mines been on since 04 still no sign of being plugged ,its gray also im not to worried i have seen no sign of dirt on the intake pipe
Old Oct 14, 2012 | 01:45 PM
SIXSLUG's Avatar
^^^same here, not going to replace it if I don't have to.
Do you guys blow yours out? I have always felt this can damage the filter media.....
Old Oct 18, 2012 | 05:58 PM
iwhitne's Avatar
You're never suppose to blow out air filters.. it cause the particles to "slice" thru the filter creating larger holes which actually allow more dirt to get thru.... imagine sticking a tooth pick thru a slice of cheese.. when you remove it you have a large hole.... get it? when the filter gets dirty.. throw it out!
Old Oct 18, 2012 | 09:58 PM
SIXSLUG's Avatar
^^^Yeah, I agree.
We used to blow out the outer filter at the Cement Plant on the 970 and 980's, but it also had an inner filter we would only replace.
I didn't think blowing out a single filter would be a good idea.
Old Oct 19, 2012 | 08:58 PM
Clunk's Avatar
Mine's been on several years too. I drilled mine for the filterminder also and it's showing ok.
Rickcher
Sep 2, 2009 05:08 PM
Ace
Oct 31, 2007 06:46 PM
Farmer
Dec 3, 2003 11:49 AM
berner
Oct 11, 2003 07:12 AM
McGyver
Dec 14, 2002 09:34 PM
