Baseline Dyno
Old Jul 19, 2004 | 04:23 AM
ramtd02's Avatar
Baseline Dyno
Has anyone with the 235 hp ISB and a 47RE put down a baseline pass on a dyno? I am getting ready too do some mods as you can see in my sig, and i want too follow how much each mod actually makes.
I am guessing 30-32% driveline loss. So that should put me in the 170 hp and 340 TQ range.
I am going to do a couple passes tomorrow evening or tuesday....depending on time. I will post my results.
Old Jul 19, 2004 | 04:02 PM
phox_mulder's Avatar
I dynoed mine stock and came up with 190 and 205
(or thereabouts, memory is failing fast)
One was on a mustang and the other a dynojet.
Can't remember which is which, but I have it written down at home.
I think the 190 was with the bigger tires though, 205 was with the stock 265's, if that makes a difference.
phox
Old Jul 19, 2004 | 04:42 PM
RATTLINRAM's Avatar
Here is a chart of mine when it was stock. The two higher HP runs were with a borrowed VA box from DavidTD. After taking my truck for a short spin with the VA,,,,,,,,, it didn't take long for me to invest in a Edge EZ,,,,,,,,,,, which started my TC slipping,,,,,,,,, and I will hopefully see what the change is when I dyno this coming weekend with mods listed in my sig.
Old Jul 19, 2004 | 05:16 PM
You have an aluminum driveshaft though
phox
Old Jul 19, 2004 | 10:28 PM
ramtd02's Avatar
Thanks guys....went down to the local shop, gotter dynoed on a dynojet.
Cam up with 199.2 hp @2600 rpm and 387.9 TQ@ 1500 rpm. The TQ curve though is basically flat as can be from 1400-2800. But the peak is the one that shows.
Too bad i dont have a scanner.....maybe i will try too see if i can buy a cheap one one of these days. But BOMBing comes first and foremost!!
Rick 12v CTD
Aug 12, 2009 10:17 PM
Stainless
Oct 16, 2008 03:24 AM
fishin fever
Apr 16, 2006 09:46 AM
mhuppertz
Oct 11, 2004 08:22 AM
gnx478
May 12, 2004 11:33 AM
