Baseline Timing for New Pump Install
Old Oct 9, 2004 | 10:07 PM
mhuppertz's Avatar
How do I set the baseline timing when installing a new pump?
Old Oct 10, 2004 | 05:26 PM
mopar2ya's Avatar
Line the hash marks up on the side of the pump and cover then get it to a shop to time it ASAP.
Old Oct 10, 2004 | 11:19 PM
cLAYH's Avatar
Usually the pump is static timed when rebuilt. Install the pump, tighten it down and then remove "lock screw" in the pump. This should be close enough to get it running. More performance can be gained by increasing the timing. If it was rebuilt stock its probably fairly low.
Old Oct 10, 2004 | 11:49 PM
mhuppertz's Avatar
Thanks for the reply. Where is the "lock screw"?
Old Oct 11, 2004 | 12:17 AM
cLAYH's Avatar
Do you have a manual? Screwing in the lock screw in usually the one of the first steps in removing the pump.
It screws in to the side of the pump below the throttle shaft just back from the mounting flange. Your pump should have a u-shaped washer wire tied to it somewhere. The srcew/bolt needs to be backed off a couple of turns and then the washer slipped under the head of the bolt.(this is after the pump is installed)
If you can not find the washer see if its already installed under the bolt. If it is then you are on your own for timing and I would question the professionalism of the shop that sold you the pump.
Old Oct 11, 2004 | 08:22 AM
mhuppertz's Avatar
The rebuild did have the key wired to it, and I put it in before I totally understood the proceedure. Since my locating pin on the engine doesn't work I guess it's a wash anyway.
I'm going to use a dial indicator on the top of the piston through the injector hole to find TDC, then I will remove the washer from the pump and lock it in. I guess this will get me close. Then I can advance it 5 deg.
Thanks,
Mark
AkitaSumo
Jul 17, 2007 10:30 AM
BC847
Apr 14, 2007 09:17 PM
fishin fever
Apr 16, 2006 09:46 AM
ramtd02
Jul 19, 2004 10:28 PM
gnx478
May 12, 2004 11:33 AM
