Ball Joints
another good trick is to load up your ball joint press, then get a large hammer and hit the spindel housing (right where the BJ goes thru)and you will find the balljoint press is loose so tighten it up aging and hit again, I've yet to find a BJ that wont come out this way, as for the hub I do the same thing, I used a hydralic jack between the frame and a bolt thats threaded into the hub, load it up and hit the spindle area hard it will edventually start moving.
another good trick is to load up your ball joint press, then get a large hammer and hit the spindel housing (right where the BJ goes thru)and you will find the balljoint press is loose so tighten it up aging and hit again, I've yet to find a BJ that wont come out this way.
. I've done a few balljoint job's, these were by far the most stubborn I've come across
firebill1720
20
Mar 5, 2010 09:23 AM
njmaier
15
Jul 26, 2006 07:43 AM
getblown5.9
May 2, 2006 10:01 PM
Seeder
Feb 15, 2006 08:15 PM
