Ball joint tools?
Old Nov 17, 2005 | 10:30 PM
CRSmith's Avatar
Ball joint tools?
I'm gearing up to replace all 4 of the ball joints on my 2001 4x4. I ordered the FSM tonight. I'm looking at tools now. Ball joint presses range anywhere from $90 to $580 (for the bling snap-on). Can anyone give me a link to a press that they know will work? How about the size fork that you used to get the knuckle off? Thanks.
Old Nov 18, 2005 | 12:04 AM
rockwithjason's Avatar
Check out quad4x4.com. They have all the goodies. I used an air hammer to get my knuckles off.
Old Nov 18, 2005 | 12:28 AM
99 cummins's Avatar
We used a combination of me twistin on the press and the kid beatin it with an air hammer, took a while but finally broke loose. Go to Auto zone and rent the press, no need to buy it.
Old Nov 18, 2005 | 01:06 PM
clhumm's Avatar
great site. wish i could put their disclaimer on my business card. the one about not answering the phone bc of fishing, hunting or bailing hay
Old Nov 20, 2005 | 12:24 AM
rebal's Avatar
I bought a ball joint press from autozone $90 it worked just fine it was the hub assemb. that didnt want to come off
Be very carefull when pulling and installing axle shafts I screwed my self doing it i tought iwas being real carefull but now the right side leaks like a stuck PIG
Old Nov 21, 2005 | 08:02 AM
CRSmith's Avatar
Thanks for the replies. I ordered one from Harbor Freight. Hopefully, it will do the trick.
Old Nov 21, 2005 | 02:09 PM
Contractor's Avatar
The Harbor Freight one works fine. Done mine on my 01 twice with it. Took about 4 hrs & 2 respectively
Cole
Old Nov 21, 2005 | 10:32 PM
I broke the harbor freight press doing mine. I did three ball joints ok but the 4th was just too much. The press broke right in half. Luckily there was a place nearby where I could barrow one.
Old Nov 22, 2005 | 12:28 AM
BigBlue's Avatar
Be careful doing this. My roommate just had his done by a shop and they ended up spending 2 hours per side cutting the lower ball joints out with a torch. This place does front end work on lifted trucks and RV's. They said this was one of the worst ball joint experiences they've ever experienced.
Old Nov 22, 2005 | 12:48 PM
99 cummins's Avatar
It may have been the wrong thing to do cause I've never heard anybody talk about it but when we put mine back together I smeared em with anti sieze. This was a prep for the next change.
Old Nov 22, 2005 | 12:49 PM
BigBlue's Avatar
Smart man.
Old Nov 22, 2005 | 01:09 PM
67HotRod's Avatar
We have had to use the torch on a few 01 dodge's. I think Dodge put them in with jb weld.
Old Nov 22, 2005 | 09:58 PM
rebal's Avatar
there in tight i had to rap the press with a hammer to get it to start moving
"anti sieze " is what you want to put it back together with
Old Nov 22, 2005 | 11:36 PM
99 cummins's Avatar
That sounds familier
Old Nov 24, 2005 | 11:21 AM
ellerman's Avatar
How many miles do you guys get out of a set of balljoints? My truck has almost 65K on it and I think they are done but I'm wondering what everybody else gets. I've owned my truck for 20K and have had nothing but front end problems but haven't changed the balljoints.
