axle swap help needed.97 into a 2000
ive searched unsuccecfully for an answer. i bought a 2000 to fix for my wife to drive with a bent dana 70 rear axle. i picked up a 97 dodge dana 70 to put in. will the speedometer work off the tone ring for the abs ? is it the same ring and pickup? if not what do i need to do to make the speed sensor work? help appreciated thanks. ratios are the same
The rear diff sensor is for ABS for sure.
NOW, what all else it does? Depends on who you ask.
In 1998ish they stopped putting a speedo sensor in the transmissions and transfer cases. Well, an "external" one anyway. I've been told it's now internal....AND...I've been told it reads off the rear diff also.
But, I've never needed to find out for sure yet, so....I dunno.
I was just pretty sure the sensors on the rear diff had a different plug from 97-98.
lincolnproberts
Dec 5, 2012 12:13 AM
bowhunter96
May 4, 2012 06:25 AM
rustydeeretech
17
May 21, 2011 03:05 PM
kawi600
32
Oct 17, 2006 08:12 AM
cumminsdriver635
Nov 29, 2005 08:29 PM
