axel nut size?
Old Jun 14, 2010 | 11:13 PM
oldblues's Avatar
Question axel nut size, bearing clearance ?
hi
98-2500 4x4
what is the correct front axel nut size , need to get a socket for it ?
also the torque to tighten it to ?
also what procdure does the factory manuel use to test the bearing play and what is the tollerance ?
thank you !
Old Jun 15, 2010 | 06:45 AM
swordfish's Avatar
Not sure if its the same, but my '01 took a 1 11/16" socket. Had to use a cheater bar to get it broke loose this past weekend. My FSM says to torque to 175 ft-lbs. Hope that helps..
swordfish
Old Jun 15, 2010 | 06:51 AM
JoshBrown's Avatar
Nape sells the specific socket for $50. It is the size fish said.
Old Jun 15, 2010 | 06:54 AM
swordfish's Avatar
If you have a northern tool close I got mine there. The one I got was an impact socket, lifetime warranty and was less than $20 .
swordfish
Old Jun 15, 2010 | 11:00 AM
Hodge's Avatar
Same here, different store, but I got mine for less than $20.
Old Jun 15, 2010 | 10:03 PM
oldblues's Avatar
hi
thanks for the socket size and torue requirment !
will watch for that one at some flea mkts , see them for about $5 each there .
found out did not need to replace wheel bearin as the mounting bolts had come loose .
just tightened them with a breaker bar this time ,apearantly i did not have enough torque on them when i had them off to reface the rotors ??
Old Jun 15, 2010 | 10:20 PM
sheriffav8r's Avatar
Get a 3/4" drive breaker bar and socket from NorthernTool when you do need to get that nut off. You really have to stand (and jump) on it to break it free and torque it back up.
Clane
Jun 2, 2012 03:31 PM
artieb
Mar 4, 2008 11:16 AM
Dr. Evil
Mar 18, 2007 11:28 AM
JImbo1
Apr 9, 2003 07:46 AM
