Average tranny temp?
Old Jul 27, 2008 | 06:17 PM
nike's Avatar
I just got my tranny temp hooked up on my Adrenaline and was wondering what temps you guys see on a daily basis? I have a built Suncoast, billet convertor, double dep pan... etc What temps should I be seeing??
Old Jul 27, 2008 | 08:22 PM
nitrousn's Avatar
Where is your probe? Pan or line?
Old Jul 27, 2008 | 09:10 PM
dozer12216's Avatar
Line will show higher temp than pan. Recomend pan location. Generally run less than 180. Pull hill/load in lower gear will go much higher. Try to max out at less than 240 degrees. Change fluid when starts turning brown.
Old Jul 28, 2008 | 07:07 PM
sheriffav8r's Avatar
I see about 150 doing 70mph with an empty truck.... My probe is on the lower right test port of the pan.
Old Jul 28, 2008 | 07:56 PM
2500Ram's Avatar
Or the block of the trans above the pan?
In the pan is better, hot line best IMO, on the block mount your getting residual heat from the fluid and heat from the casting not a true fluid temp, pan your getting a temp after it's been through the cooler, hot line your getting a temp after it's been in the converter with no cooling on it's way to the cooler.
150* sounds right for your location though.
engcogod
52
Mar 23, 2015 02:26 PM
dieselnewbie
14
Aug 27, 2004 10:46 PM
JBirney
Nov 12, 2003 01:40 PM
cethane
Jul 31, 2003 12:59 PM
