Automatic transnmission - Not TC I think
Old May 1, 2007 | 01:19 PM
Silverjay's Avatar
My auto has been doing weird things the last few days. I have been through the TC lock/unlock thing at around 50 mph and this is not that. When the truck sits for a day or so it will accelerate fine to 60-70 mph. After that it will "chatter". it feels like a TC, but does it under all throttle positions. The only way I can get it to stop is to drop it out of OD and run at 65 mph for a few minutes. When I go back to OD it behaves. It will then run normally untill parked for a day or so. I already did the battery cable connections. It alsmost seems like internal leakage?? I did a VB kit 7,000 miles ago with no apparent issues.
Old May 1, 2007 | 09:05 PM
Silverjay's Avatar
No ideas? Not even a guess?
Old May 7, 2007 | 08:29 PM
Silverjay's Avatar
I figured something out, but I don;t know what it means. If I let the truck idle in gear for a minute or so before taking off it drives great. If I don't, the TC chatters. Does this sound fluid related and not electrical?
Old May 10, 2007 | 10:48 AM
Silverjay's Avatar
I read on another posting about water level in the batteries effecting the TC control. When I checked the battery water level, it was low. I topped them off and the problem went away.
Old May 11, 2007 | 03:44 PM
j-fox's Avatar
I want to interupt you, as you talk to yourself!!!
What you decribe is a torque converter leaking down overnight. It slowly drains into the pan. This then takes a few seconds to refill. Usually 30 -45 seconds.
This is a trait of the dodge auto's, it really means the converter bushing is getting loose( it could be other things), and really won't cause you a problem if you start the Cummins, let it idle in neutral for 30-45 seconds. I have seen tired fluid cause this too.
Ok, you can continue with this conversation by yourself!!!
( I'm a SA)
rossco
Aug 23, 2007 06:17 PM
t-15 firefighter
Jan 16, 2006 09:08 PM
Don H
Jul 9, 2004 07:47 PM
akgoldminer23
Oct 5, 2002 11:07 PM
