Automatic trans controlers
Old Jan 13, 2012 | 09:16 PM
travelingman's Avatar
Who makes the best controuler that can be used with a 47re . I've got a Goerend ordered an they've told about just installing a toggle switch to lock the converter . But dozen't someone make a controuler for the forty seven that has settings for towing economy an performace or use with exhaust brakes ?
Old Jan 17, 2012 | 10:59 PM
turbottype's Avatar
Yes they do. For towing the controller can lock up 3rd gear for engine braking going down hill. Same thing also in 2nd gear down hill and will unlock the converter when is at 2500 RPM so it damage the converter. Same thing going up hill, you can lock 2nd gear 3rd gear. With the switch if your tranny can be damage if you forget to turn it off. Also if you lock up before the RPM are up you can damage the converter & clutches due to low pressure PSI. For exhaust brake you will need heavier exhaust springs and enjoyed the ride down hill.
Old Jan 18, 2012 | 10:38 PM
turbottype who makes the controller ? An thanks for the info
George
Old Jan 19, 2012 | 07:06 AM
turbottype's Avatar
George
DTT BD diesel sell them.
Old Jan 19, 2012 | 07:34 AM
maxwellp's Avatar
I would like this too. I would like to change shift points and converter lock up. Let me know what you find.
Old Jan 19, 2012 | 04:49 PM
Ok i'll check it out thanks . I just noticed what you said about heavier
exhaust springs when installing a E Brake . What brand brake are you running an is it what you'd recommend if you had it too do over?
cougar
Jun 5, 2015 10:21 AM
lifer
Sep 3, 2009 07:34 PM
smokin 5.9
Mar 5, 2008 10:24 PM
TPilaske
Jan 28, 2003 10:47 AM
wick
Nov 1, 2002 02:00 PM
