Anyone install a PTO driven device on their truck?
Old Dec 1, 2010 | 11:59 AM
KATOOM's Avatar
I'm looking for any PTO driven device thats made for the 2nd gen trucks with PTO capabilities. ANYONE know of one? I cant find anything on the internet.
Old Dec 6, 2010 | 10:09 PM
totalloser's Avatar
You buy the pto drive unit and then attach anything you want to it. There are a few units that direct marry to pto units, but they are usually just a standard size hydraulic pump.
A while back I went looking for an excuse to mount a pto on mine, and found a pto drive unit. They are sourced by the transmission or transfer case.
I'll see if I can't dig it up. Chelsea and Muncie are big names in the pto business.
Old Dec 6, 2010 | 10:18 PM
totalloser's Avatar
http://www.munciepower.com/main/quick-reference/ check this out and punch in your transmission. PDF for a few options-different gear ratios for the pto. Once you have this component, you can hook it to nearly anything.
Space is an issue, though. One side has exhaust, the other a driveshaft. If you have a 241hd transfer case, you can mate to that, too.
The six bolt pattern is universal, but I don't think the gear pitch/depth is, so beware. I *think* you can often change out the gear to use a junkyard pto if that pto was a option on your transmission.
Old Dec 6, 2010 | 10:30 PM
KATOOM's Avatar
There is no NV4500 option.....unless I'm missing something.
Old Dec 6, 2010 | 10:44 PM
Tate's Avatar
http://www.munciepower.com/clientupl...ns/NEWV-01.pdf
Old Dec 7, 2010 | 04:08 PM
totalloser's Avatar
Thanks Tate, I tried to figure out how to post that up, but still a bit cave man.
BTW that pdf shows the chart for a Chevy NV4500, but Muncie's link to it is from the Dodge link, so I'm guessing they are the same. Since there were smaller OTR tucks that ran the NV transmissions, theoretically a junkyard score might be possible... theoretically.
Old Dec 7, 2010 | 07:08 PM
Tate's Avatar
Early chev NV4500's were different than the dodge ones, with the deeper first gear and case differences. The later chev's (after whatever build date) is the same as the dodge's.
Old Dec 7, 2010 | 08:17 PM
KATOOM's Avatar
Thanks guys. Making some phone calls to see whats still available.
JBradley500
Jun 1, 2016 07:53 PM
Dodgezilla
Nov 9, 2010 04:31 PM
hitcb1789
Jul 11, 2010 02:34 AM
dodgetrucker75
Sep 21, 2009 12:52 PM
jlipskoc
Jan 23, 2007 05:37 PM
