any ideas???
Old Sep 14, 2009 | 06:31 PM
kicker210's Avatar
any ideas???
i checked my codes today by cycling the key a couple times and it came up with the 1693 and then followed by an overboost code.
i have a boost guage and before when i had the guage installed i was only making 11psi, which is half of what holset says, which it should make 20-22psi stock. so i added a the BD Boost elbow and it worked raising the boost to 18psi.
so heres my trouble if at first i was only making 11psi and then up little more to 18psi and the max that the HX-35 can handle is 36psi before turning into shrapnel why am i getting the overboost code???? is my guage faulty or is there something more to the problem??
Old Sep 14, 2009 | 07:03 PM
ericg's Avatar
this may or not help but mine had been doin that for about the 8 mos and i just discovered that my vp-44 was goin south and defueling in the higher rpms,but it never tripped anything but overboost until last week when i got a code 216
Old Sep 14, 2009 | 11:10 PM
rebal's Avatar
are you sure you don't have a boost leak some where ?
Dufrain
Apr 5, 2005 09:00 PM
JoeDiesel
Mar 13, 2003 06:36 PM
MoParr
14
Feb 18, 2003 12:19 AM
blackboat
Jan 10, 2003 02:50 PM
tomsauto
Nov 19, 2002 07:18 PM
