Any experience with oil dye?
Old Apr 12, 2017 | 11:24 AM
DieselVeins's Avatar
I bought some fluorescent oil dye that is used with a light to help find oil leaks. Was wondering if anyone has used something like this and if so, did you have better success when the oil was dirty or fresh after a change? Also does it make a difference if its easier to see in the daytime or at night? Thanks
Old Apr 13, 2017 | 08:34 PM
brophyn70's Avatar
I used it once in a motor and did it with dirty oil on a gasser. What I did was clean everything really well under the hood and underneath, let it dry. Dumped the dye in, let it run for a while to let it leak oil back out, and searched with a black light which lit the dye right up. It was daytime when I did it inside and had no issues finding where it came from
Old Apr 14, 2017 | 01:02 PM
Busboy's Avatar
I have used it in air conditioning on vehicles and really had not much luck, visually seeing the refer oil or using an electronic Freon detector works way better. Engine oil use is definitely different though.
rustyshakelford
Sep 6, 2006 05:29 PM
Begle1
49
Oct 25, 2005 04:04 AM
HURA1
Sep 9, 2005 10:27 PM
HURA1
May 18, 2005 11:00 PM
I PASS GAS
Sep 7, 2004 01:52 PM
