Anti-Slip Modifier Getting Weak?
Old Mar 5, 2007 | 08:30 PM
Geico266's Avatar
Anti-Slip Modifier Additive Getting Weak?
I changed my rear differential fluid about 2 years ago, and I added 6-8 OZ of the anti-slip differential modifier. Everything was fine until about 2-3 months ago when I noticed the differential would shutter going around tight corners under a load.
I changed the differential fluid again tonight and added 8 oz of modifier. Seems to work better right away doing figure 8's in the parking lot to mix it up.
Does the modifier wear out? Anyone else notice this?
Old Mar 5, 2007 | 11:04 PM
J BODY's Avatar
.....I see it quite often. Lack of scheduled maintenance.
Old Mar 7, 2007 | 06:50 PM
Geico266's Avatar
Changing the fluid sure took care of the problem. Learn something new everyday here.
I would think the additive would last longer than 50K miles. I don't tow that much so I stretch the changes.
Change that differetial fluid boys & girls!
Old Mar 8, 2007 | 03:17 PM
billmac's Avatar
I replaced the differential fluid in my truck 15k miles ago and put in 2 ozs. of the Mopar Limited Slip additive. Everything worked fine until about two weeks ago when the truck started to get a little chatter going around corners. It's really not that bad and I've read that a little chatter is not harmful. If it gets worse, I will add another oz. or so of additive.
Old Mar 8, 2007 | 04:11 PM
wrm's Avatar
wrm
Why Do The New Trucks Not Need Additive,they Call For The Same Gear Oil.
Old Mar 8, 2007 | 04:27 PM
billmac's Avatar
I believe the 3rd generation trucks use the American Axel differential instead of the Dana which was used on first & second generation trucks. The anti-spin set-up is different between the two. I'm currently using a synthetic fluid which has the additive in it; however, additional additive may be required depending on how "tight" or loose" the clutch packs are in the differential. I believe that's correct. I don't think the American Axel differential uses clutch packs.
Old Mar 8, 2007 | 04:54 PM
wrm's Avatar
wrm
it is a AMERICAN axel so that explains why . thanks !
wcbcruzer
Jul 13, 2008 07:10 PM
Lyall
Sep 7, 2006 06:38 AM
mopar2ya
Aug 26, 2004 12:23 AM
BADodge2003
Aug 24, 2003 07:22 PM
timdewaltman
May 15, 2003 10:30 PM
