Which Amsoil
Old Jan 16, 2003 | 01:05 PM
sdscuba's Avatar
Which Amsoil
Which Amsoil in engine?<br><br>Which Amsoil in Diff?<br><br>Which Amsoil in Tranny?<br><br>Driving in California (Warm Climate), 20% towing, stop and go, sustained high speeds whenever I can.
Old Jan 16, 2003 | 02:02 PM
P Kennedy's Avatar
Re:Which Amsoil
We have run the 15-40 Diesel/Marine oil in both engines 91/2001, transmission only has 1 choice and run 85-140 series 2000 gear oil with no additive. T case if you have one is same oil as tranny. PK
Old Jan 17, 2003 | 11:08 AM
KC's Avatar
KC
Re:Which Amsoil
[quote author=P Kennedy link=board=4;threadid=9709;start=0#92838 date=1042747336]<br> We have run the 15-40 Diesel/Marine oil in both engines 91/2001, transmission only has 1 choice and run 85-140 series 2000 gear oil with no additive. T case if you have one is same oil as tranny. PK<br>[/quote]<br><br>I will second that!<br><br>KC
Old Jan 17, 2003 | 03:23 PM
BigK's Avatar
Re:Which Amsoil
This is my third CTD. Started in '90.<br><br>15-40 HDDM in every one of them after break-in.<br><br>M/Hytec just arrived today, rear will get ser. 2k 75-140. Will start w/no additive. Worked well in last two without.<br><br>Still researching trans &amp; case<br><br>front will get 75-90
Old Jan 17, 2003 | 05:19 PM
Dieseldude4x4's Avatar
Re:Which Amsoil
AMSOIL front to rear<br>15W40 Marine Diesel in the crank case with dual remote system (25000 mile change intervals with sampling)<br>75W90 in the front axle<br>75W90 Series 2000 in the manual trans with Transcoolers also<br>Synthetic trans fluid in the trans case<br>75W90 Series 2000 in the rear axle with Hytech-cover<br><br>Not telling anyone what to do, just what works for me.
Old Jan 17, 2003 | 09:38 PM
Dave65's Avatar
Re:Which Amsoil
[quote author=dieseldude4x4 link=board=4;threadid=9709;start=0#93274 date=1042845580]<br>AMSOIL front to rear<br>15W40 Marine Diesel in the crank case with dual remote system (25000 mile change intervals with sampling)<br>75W90 in the front axle<br>75W90 Series 2000 in the manual trans with Transcoolers also<br>Synthetic trans fluid in the trans case<br>75W90 Series 2000 in the rear axle with Hytech-cover<br><br>Not telling anyone what to do, just what works for me.<br>[/quote]<br><br>I will second that
Old Jan 17, 2003 | 09:41 PM
Don M's Avatar
DTR Advertiser
Re:Which Amsoil
Amsoil = yummy....I like to butter my popcorn with it :<br><br>The universal tranny fluid makes great wax too <br><br>Don~
Old Jan 17, 2003 | 10:31 PM
DEZLPWR's Avatar
Re:Which Amsoil
[quote author=Don M link=board=4;threadid=9709;start=0#93365 date=1042861312]<br>Amsoil = yummy....I like to butter my popcorn with it :<br><br>The universal tranny fluid makes great wax too <br><br>Don~<br>[/quote]<br><br>LMWAO! <br>Tell us how you really feel Don!
Old Jan 18, 2003 | 07:47 AM
wildolman's Avatar
Re:Which Amsoil
I found the Amsoil website somehow and they have a tech line. Sent my specs to them with what I wanted to do and had an answer the same day. Flush is easy but they don't have auto trans fluid for the'02 :'( :'(
Old Jan 18, 2003 | 08:41 AM
turbo thom's Avatar
Re:Which Amsoil
Now all y'all just don't understand , don't get Don started. He will burn your key board and cause the monitor to &quot;BUST&quot;. Just stay calm and easy and don't start nuttin. <br><br> As far as Amsoil goes I've used it 3 years with no ill affects. Matter of fact it has done quite well. If you trust the oil analysis my engine oil last 50K, w/ the dual bypass and I change it. Not neccesary they say but I do anyway.So far the engine is at 256K and still runnin. I tow 15K all the time. The gear oil is the best on the market. Series 2000 I mean. Anyway its blue, and I like blue.<br><br> Now what?<br><br>..Preston..
Old Jan 18, 2003 | 09:05 AM
Re:Which Amsoil
Hey Turbo T, I ran the same oil in my 89 for four and a half years, 60000 miles with the dual remote and sampling. Traded it four years ago this month on my 99 and the 89 is still going strong. It had over 142000 when traded.<br>I will more than likely stick with 25000 mile change on this truck since I have upped the HP a skosh. That is probably overkill but I don't feel bad about that interval. I change the main filter every 5000 and the bypass filter every oil change (at 25k intervals).<br>Just what works for me.
Spooler
28
Dec 26, 2009 10:16 AM
Bradleysram
19
May 12, 2009 08:36 AM
czkid
Oct 18, 2007 07:38 PM
hellotbone
27
Aug 18, 2003 08:42 AM
tlea7
Feb 6, 2003 11:56 AM
