AIC ?
Old Jan 3, 2003 | 06:30 PM
slimchase's Avatar
AIC ?
Is it possible to put an AIC on our trucks? I would guess that you could but I wasn't sure on how to do it. I saw one that gives you a range from idle to 1500 rpm but it was alot of $$$.<br>I had a home made setup on my psd that only cost me $40. Worked like a charm. All the old one was was pretty much an extra throttle via a **** on the dash, ran from the wires from the foot feed. Oh yeah there were some diodes and stuff too. I have a list. Just a thought.<br>Chase
Old Jan 4, 2003 | 03:03 PM
slimchase's Avatar
Re:AIC ?
Well what I was thinking was since there is no throttle cable on the truck I would hook up a system that would run off the wires that go from the peddle to the ecm or whatever it hooks up to. You know trick the computer into thinking that the footfeed is being pressed when it is not.<br>Chase
Old Jan 4, 2003 | 04:20 PM
Commatoze's Avatar
Re:AIC ?
I'm still figuring out what AIC stands for... ??? : :-[ ;D Accelerator [???] Control??<br>
Old Jan 4, 2003 | 05:17 PM
Ken's Avatar
Ken
Re:AIC ?
This may sound crazy, but I was just going to post the same question. An AIC is an Auxiliary Idle Controler. Ford has them as an option on thier trucks. The principal behind it is that it helps the electrical system matain the proper output when under load, i.e. heavy electricly use. The other purpose, which is what I'm looking into it for is, you can set it at a higher idle when you intend to be idling for an extended period of time which they say reduces cylinder glazing. I do a lot of plowing and salting and the truck runs for roughly 30 hours at a time. So the idle controler will allow me to ramp up the idle when I know I'll be sitting for a bit My other question is, does anyone have two alternaters installed on thier truck?
Old Jan 5, 2003 | 09:42 PM
TGCTD's Avatar
Re:AIC ?
Can't see why one of those anti-diesel solenoids from the late 70's &amp; early '80s carbed engines wouldn't work. They used to be energized w/ 12V any time the key was on to kick up idle speed and shut down the venturi to prevent the run-on common in those years. Can't see why you could'nt make up a bracket to fit. Thought about doing this myself. Let us know how you mke out. Have the cold idle enabled, but w ould like more control on temps near or above. 30 F. TGCTD
Old Jan 6, 2003 | 02:08 PM
Marine's Avatar
Veteran: Marine Corp
Re:AIC ?
There is a man named Harold from Idaho that makes High Idlers for 12 and 24 valve engines. When I get home, I will post the info. They range from 35.00 for manual, 45.00 for the autos. I have one, and it works Great!<br><br>Mike
Old Jan 6, 2003 | 06:50 PM
slimchase's Avatar
Re:AIC ?
Wow don't I feel STUPID . I was thinking about how the setup on my old PSD was and didn't realize there was a cable. So to awnser you Fitzer, they are the same. I guess when you mess with things for so long then you get rid of it you kinda forget that everything is not the same. This gives me another question, how does the dealer controll the idle when they are working on the truck? Do the push the foot feed or do the hook a computer up and it does it? I am not trying to make this harder than it is for everyone, heck I even confused myself there for a while.<br>Marine how much control does it give you? Like what range.<br>CHase
Old Jan 6, 2003 | 07:50 PM
Marine's Avatar
Re:AIC ?
Harold's PH# is 208-459-7849.<br>It has an auto shut off for the automatics when you leave park. It idles at 1200 rpm<br><br>Mike
Old Jan 6, 2003 | 08:04 PM
slimchase's Avatar
Re:AIC ?
so how does it work? in general not the auto shut off thing.<br>CHase
Old Jan 6, 2003 | 08:09 PM
Marine's Avatar
Re:AIC ?
When you want to idle up, you press the on button, ramp the accelerator up to 1200 or so, and it is on. It is a solenoid. For the manual trans, just turn it off before you put in gear. Answer your question?<br><br>Mike
Old Jan 6, 2003 | 08:13 PM
slimchase's Avatar
Re:AIC ?
yep sure does. will it only set around 1200 or is it like 1000-1400 depending on the peddle? I know I know lots of questions.<br>Chase
danlit's Avatar
Re:AIC ?
I think you`d be better off trying to break into the cruise control. It would be cool to use the controls on the wheel.<br>Someone here has to be able to figure this out.<br> Danny
