Adrenaline Issues ?
Old Nov 24, 2009 | 09:36 PM
kX500's Avatar
Adrenaline Issues ?
I have a 2001 24V. I purchased Quadzilla's Adrenaline with Pulse monitor back in June. I installed it on the truck but did not land the fuel wire at the time. I just wanted a little more power to tow my trailer, and did not want all that the module could offer at the time so level 2 was perfect. I finally got the urge to utilize the capability of the module so a few weeks ago I purchased a pump cover from Blue Chips to use as a means of landing the fuel wire rather than piercing the wire on the VP44. I installed the cover and set the screw, then landed the fuel wire. First off, after I purchased the Module back in june I noticed that I could not feel an increase in power from level 0 to 1 but a very noticable power increase from level 1 to 2. Now after the fuel wire is landed I still feel no power from 0 to 1, but more dissapointing I find that I still have no aditional power/smoke/boost from level 2 up to 10 not even a difference in EGT's. My first thaught was that the module was bad, luckly I have a brother with the same setup. I installed his Adrenaline in my truck but the result was no different, I guess that rules out a bad module. I can measure 12.6 volts on the fuel wire with the ignition on which tells me that the fuel wire circuit is good. I am wondering if there may be a problem with the engine ecm or with the VP44. My thaught however, is if there was a problem with the ecm or VP44, why would I get power on level 2, I would think that I would not get power at any level. Which brings me to my final thaught. Could the Pulse controller/monitor, or the communication between the Adrenaline and the Pulse cause the Adrenaline not to respond to the power levels that I select? Has anyone seen or heard of such an issue or have any light on the subject?
I just realized that I posted this in the wrong forum, I apologize. I have reposted this in the correct forum.
Last edited by kX500; Nov 24, 2009 at 10:13 PM. Reason: Accidently posted in the wrong Forum
Erik42069
May 30, 2012 10:44 AM
kX500
Nov 27, 2009 06:36 PM
SpunkysRam
Aug 17, 2008 01:14 PM
qzilla
218
Jan 30, 2008 08:20 AM
vzdude
Oct 17, 2007 04:32 PM
