ABS and PBRAKE light wont go off....
I blew a rear brake line awhile back and my ABS and PBRAKE light came on. I know my ABS doesnt work anymore, how do I fix this? Thanks for any help
Josh
Josh
Are you just rear wheel abs? If so then it could be the sensor. Even if you have four wheel abs it still could be the sensor but it makes it easier to troubleshoot. Remove the sensor at the top of the rear diff and check it's function w/a multi meter. As I recall it should show 1800 ohms resistance. Mine was bad and it showed 'open'. Replacement is about $40 from dealer.
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
j28s
Dec 5, 2002 07:33 PM
