99 won't start
Old Apr 18, 2009 | 07:27 PM
farmboy1973's Avatar
99 won't start
this is my dads truck nothing has been done to it I was driveing along when it just died won't start but with eather got fuel to filter to the injecters but it won't start can't get any dash codes the last time this happend fuel gauge was wrong and run out of fuel but not this time thanks
Old Apr 18, 2009 | 09:27 PM
dozer12216's Avatar
My reply posted on Cummins Forum. Good luck.
Old Apr 19, 2009 | 12:29 PM
dozer12216's Avatar
No way it jumps time.
Old Apr 19, 2009 | 08:16 PM
I took it to auto zone today they got a code 1688 is there any thing I need to check before buying a pump? If I take 3 injectors lines loose it will try to start
Old Apr 19, 2009 | 08:26 PM
BigIron70's Avatar
Cummins Guru
Load test the injection pump power and ground at the injection pump connector using a head light as a load Clear the fault codes, turn the ignition key OFF for at least 60 seconds, turn the key ON. Without starting or cranking the engine, check if p1688 resets. If p1688 resets at key ON, replace the injection pump. If the fault only resets with the ENGINE RUNNING, look for a loose power or ground connection to the injection pump, or a bad fuel injection pump relay.
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
