99 Dodge cummins
Old Jun 30, 2009 | 01:22 PM
Rick2's Avatar
99 Dodge cummins
overdrive seems to be searching in the 45 to 52 mph range is there an adjustment to increase overdrive kickin at say 52 and up
Old Jul 8, 2009 | 01:31 PM
VADSLRAM's Avatar
It's the converter lockup not the OD. Search the forums and you'll see a ton of solutions from APPS reset to tinfoil hats...I mean covering of wires. Mine has been doing it intermittently for years but just started getting worse so I came here for answers myself.
Old Jul 9, 2009 | 09:48 AM
high bid's Avatar
double check making sure the batt grounds are tight and clean.
Old Jul 9, 2009 | 09:40 PM
dozer12216's Avatar
All grounds and power lead connections, including alternator should be cleaned and properly installed. Sometimes just wrapping alternator leads with a fine wire and grounding the wire will shield. Adding a condenser to bat terminal and bolting to alt housing will stop issue. There is no ONE FIX fits all story here.
1stgenatheart
Oct 19, 2009 06:33 AM
wreedCTD
27
Sep 30, 2007 09:52 PM
96_12V
Jul 17, 2007 07:03 PM
ProjectM880
Dec 1, 2004 06:40 PM
texasredrider
30
Nov 14, 2004 10:35 PM
