99 2500 Transmission not shifting out of first
Old Oct 23, 2011 | 03:16 PM
typz2slo's Avatar
My transmission will not shift out of first on its own. It will redline but if you let up on the throttle it will shift out of first and the rest of the gears shift fine. I have changed the output speed sensor on the drivers side of the transmission but not sure what else to look for. The transmission is stock and the truck is 4wd with 224000 miles on it. Any help on this will be appreciated. Thanks
Old Oct 23, 2011 | 05:57 PM
m.t.hands's Avatar
not sure but welcome to DTR, i'm sure someone will be along soon that'll have you pointed in the right direction (i mean gear)
Old Oct 23, 2011 | 05:59 PM
samaf's Avatar
I had a shift problem with the truck in my sig and it turned out to be a broken wire in the harness going to the trans. Good luck.
Sam
Old Oct 25, 2011 | 09:30 AM
typz2slo's Avatar
Looks like its skipping 2nd gear so if a band adjustment wont fix it. A rebuild may be in the future for it.
whyryguy
Jun 17, 2013 04:48 PM
patg
Sep 23, 2010 12:30 AM
Tractor Truck
Aug 23, 2010 11:27 PM
DodgenIt
Feb 20, 2008 01:59 AM
00' Quad Cab
Sep 15, 2007 01:44 PM
