98.5 transfercase
Old Feb 11, 2010 | 01:32 PM
jivemother's Avatar
Exclamation 98.5 transfercase
working on 98.5 24 valve.. transfercase is junk hunting junk yards for one . everone is asking me if it has a pto gear . i dont need a pto gear . are they the same mounting and function between one with gear and one with out ?
i beleive it is a 241 hd need help fast lots of snow to plow ...
Old Feb 11, 2010 | 01:58 PM
dozer12216's Avatar
Difference between 1500 and 2500 +. Light duty no pto. The number on round tag at rear of case is all identifing.
Old Feb 11, 2010 | 08:27 PM
nitrousn's Avatar
Plus the output shaft is larger. For a correct fit you need the 241 dhd.
We just bought one from these guys. Good product and service.
http://www.transfercases.com/
Old Feb 11, 2010 | 08:51 PM
jivemother's Avatar
thanks for the help , i can get one from junk yard for 800
Old Feb 11, 2010 | 09:36 PM
Tate's Avatar
The cummins had both the 241DLD and the 241DHD. The difference is the DHD has a pto cover and is longer. If you have the LD and buy the HD, you will have to get your driveshaft shortened.
Make sure you get one from the same transmission as your truck. Autos have a 23 spline input, manuals have a 29 spline input.
Old Feb 13, 2010 | 03:54 PM
nitrousn's Avatar
Are you sure the cummins had the 241DLD???? As far as i know the 241DLD and a smaller output shaft diameter and was used in gas applications not diesel.
Old Feb 13, 2010 | 05:11 PM
rattlerbob5.9's Avatar
Tate has it correct DLD = diesel light duty and DHD = diesel heavy duty
DHD is the one with the pto cover and length is different.
DHD was an optional upgrade in a 2500 series truck my 96 was ordered that way.
Old Feb 13, 2010 | 07:17 PM
nitrousn's Avatar
DHD=Dodge heavy duty
DLD=Dodge light duty
So when the DLD is in a diesel application it has the smaller output shaft???
Old Feb 13, 2010 | 09:20 PM
slowflyer2112's Avatar
I have a DhD for an auto available. Its in perfect condition with about fifteen thousand since rebuild. Let me know if your interested.
Old Feb 14, 2010 | 09:16 PM
jivemother's Avatar
what u looking to get for it ? were u located
Old Feb 14, 2010 | 09:17 PM
jivemother's Avatar
wow cali far away shipping would suck
Old Feb 14, 2010 | 10:14 PM
Hodge's Avatar
Mine does. Same torque rating as the DHD, just without the ability to run a PTO. Even the DLD is heavier than the 241 in the half tons.
You need the number off the transfercase that you currently have. There are over 20 model variations used in these trucks, and that number needs to match unless you want to open it up and start switching parts.
Old Feb 14, 2010 | 10:15 PM
Hodge's Avatar
DLD and DHD means Diesel Light Duty and Diesel Heavy Duty.
blazepurplehaze
Sep 1, 2005 09:10 PM
2500TurboDodge
Jan 25, 2005 12:56 PM
slowflyer2112
Jan 15, 2005 11:42 PM
dieselman24
Feb 10, 2004 08:52 AM
sshelly
Jul 10, 2003 11:07 AM
