98.5 to a 01 engine
Old Mar 30, 2006 | 01:05 AM
MFEUSAF's Avatar
98.5 to a 01 engine
i have came apon a wrecked 01 for cheep and i was wondering if i could swap the engine from the 01 to the 98.5 with no problems. i have a severly cracked 53 block and engines are hard to come by. any suggestions would be appreciated.. thanks
Old Mar 30, 2006 | 06:43 AM
Truckman's Avatar
Talking Crank Sensor
Make sure it has a Crank sensor,,, Somewhere in 2001 they stop using the crank sensor,,, For your 98.5 the ECM needs to see the crank sensor.
Do a search for this swap on this forum,, You will find a couple of us here are doing it Now ,,,, I start mine this Friday Noon Time,,,
Check my Gallery out for the repair for your #53 Block,,, Mine has not leaked for 10000 miles now..
Do a search for this ,.. 98 to 01 engine swap
Old Mar 30, 2006 | 09:36 AM
SpicyJam's Avatar
The '01 will work, the tone ring, (crank sensor as called above post) has been done away with in the 01's. The same function is instead of the crank having a tone ring the sensor is now reading off the cam. That is all. Later Jim.
Old Mar 30, 2006 | 10:29 AM
Truckman's Avatar
I just bought an 01 It has the crank sensor there ,, I dont know at what date they started doing away with them,, BUT I have been told the 98.5 ECM NEEDS to see that sensor..
I will let you know after this weekend,, Cause I am Installing my new 01
Old Mar 30, 2006 | 11:39 PM
John DiMartino's Avatar
it will work,but you may have to change the entire front cover over,as the cam sensor location and connector may be different.Take a look,and see if they appear the same.The vp also has a different part number in 01,not sure if the connector is different or not.
Old Mar 31, 2006 | 06:24 AM
Truckman's Avatar
Thumbs up Cam Sensor
I have a Good friend of mine that works in the parts dept at a Chry/Ply/dodge/jeep/ Dealership where I used to work as a Tech, I had him check all the sensor's and so far the Only one that has to be changed is the Map sensor....Cam and Crank sensors Are the same. I hope it all works,, I start doing it in 4Hours. And am Stranded ther until I get her running with the new CTD. I am SO ready To get that CRACKED #53 Block OUT,, And The New #56 Block In.
It is such a shame to Change The engine cause it runs SO good.
Old Mar 31, 2006 | 06:52 AM
MFEUSAF's Avatar
so just swap over the map sensor then? and i hear you about the 53. but new engnies are REALLY $$$$ and im just a low ranking airman in the usaf so i dont make much. well see what happens. tell me if everything goes good..
Old Apr 3, 2006 | 08:02 AM
Truckman's Avatar
Thumbs up
DONE DONE I mean DONE!!!!!!!!!!!!!
New Engine is in ,,, HEEEEEE HAWWWWW
Hi My name is Bob And I have been #53 Free For One Day Now,,,,,hahahaha
Ran into a couple of snags BUT Everything went pretty smooth,,
And as excactly stated early,, The ONLY sensor I had to change was the MAP.. I left all other sensor and used the 98.5 ECM Runs Like a Charm,,AND Holds AntiFreeze....... WOW,,.. I need a Napkin!!!!!!
Old Apr 3, 2006 | 08:54 AM
xmr's Avatar
xmr
Hi my name is john and I have been #53 free for 112 days .
Just say no to anti-freeze.
Old Apr 15, 2006 | 04:18 AM
Truckman's Avatar
Exclamation Fuel Hog
Update:::::
New engine Runs Great BUT sure is a FUEL HOG,, And at these prices thats a bad thing,,, I am thinking about putting my OLD cam in the New engine to see if that helps,,,,, The old Engine 20 -21 MPG,,
New Engine Just Sqeeking out 16.5 MPG..... Hopefully as I put miles on it it will get better (hahaaha),, Now Has 9 thousand miles on it.....
The only difference in engines is the cam and turbo exhaust housing,
Old Apr 15, 2006 | 09:16 AM
Mechanos's Avatar
If I understand you correctly, your "new" '01 engine only has 9000 miles on it? If that's the case, then I'm sure it's still pretty tight. I would expect the MPG to increase with more miles and the engines gets broke in/loosens up some.
Old Apr 15, 2006 | 12:04 PM
rebal's Avatar
its got to be cause its still new ,my 01 HO gets solid 20s + and thats still with all the mods to it
alltimelow1
Apr 6, 2005 07:28 PM
Stevenc
Dec 28, 2004 08:29 PM
apache
Feb 22, 2004 05:27 PM
