Is 800 rpm too high for idle?
no way to adjust it manual as the older 12 Valves could off the injection pump. 98.5 and up idle was controlled in a stock truck by the Computer. mine idles 850 ish. not sure if a Auto Vs Stick SO Vs HO would idle slightly diff. I may be missing something but this is my 2 dimes.
Cummins Guru
Check for bent throttle cable bracket at the APPS. Bracket may have been bent during injection pump or transfer pump replacement. Bracket may be bent enough to pull throttle cable slightly and increase APPS signal voltage above .5 volts. A slight adjustment of the throttle cable bracket will restore signal to correct output. Make sure the bell crank is against the idle stop.
I would actually like to lower mine to about 700 - 750. I'd asked Marco if the Smarty could do this several years ago but never got a response. I think if it's at all possible on the 24 valves it would be done via software.
800-850 is normal for the 24 valve trucks. Lowering the RPM speed will not be a good idea for cold weather because piston speed during compression is what generates the heat needed for proper combustion. Slower idle would mean slower piston speed. Plus the ISB produces around 300 ft pounds of torque at idle.
Attaboy KATOOM - I knew that you would show up and make me feel better! Momma and I are wintering in the "real" SOCAL (Earp) and the Beast loves to idle around the campground pulling stumps and whatever else is in the way. There are 7, yes 7, 2nd Gens here at the Big River camp ground right now - my kinda heaven.
Cheers!
Mike
Cheers!
Mike
Since we're gushing about torque, I've started my rig moving on flat ground in 5th gear (unloaded, just for funsies). The cummins just shoulders down and gets on with it. That said, I did have to put it in 4lo to idle up an icy, probably 10%+ grade with a huge load of green willow logs and brush in a trailer.. That was mostly for peace of mind. Don't like breaking things.
jmccart
Jun 12, 2007 02:12 PM
klrmark
Sep 4, 2003 09:37 PM
