53 Block
ok, today i went out to look if i had a 53 block, and i do. Now that i have one is ther any thing i can do to make it not crack. And by the way it has a little under 200,000 miles on it
Ive heard that EvansCool waterless coolant will help a fair bit. Its not cheap by any means. You can find out about it here:
http://www.evanscooling.com/index2.html
Other than that, keeping your regular coolant/coolant system in top notch condition couldnt hurt either.
Coolant system
If you haven't already.....relocate (or replumb and ditch) the breather bottle.
Do a good clean-up on the engine side of your radiator.....you won't believe
the crud around the edges that gets "glued" in there from the cast-off caused
by stock breather-bottle/fan combo.
I did mine at 51k miles and was suprised at the crud...and mine is a 2wd w/no
"offroading".
"offroading".
Use it like an S-10
Friends dont let friends drive #53"s
Good luck,,, If you want to see what your block will look like when it cracks,,, see my gallery,,
Ok, today i went out to look if i had a 53 block, and i do. Now that i have one is ther any thing i can do to make it not crack. And by the way it has a little under 200,000 miles on it
Originally Posted by eric13
I have done a search but cant find out how to see if I have a 53 block can anyone lead me in the right direction?
http://www.stamey.info/Truck/Cummins...NewInformation
Originally Posted by Dr. Evil
eric, I have posted this link on this site probably a thousand times:
.Thanks for the help anyways.
