4X4 Gurus need your help!
Old Jan 20, 2008 | 10:13 AM
craftybigdog's Avatar
Hey guys I have a 2001 Dodge 2500 with the cummins.
Here is my problem. The 4X4 light will not come on when shifted into 4 wheel drive. Also the cruise control light will come on but will not engadge. I was wondering does the cruise vacume under the driverside battery tray control the 4X4 also. Because I was just under there the other day wiring up the snow plow lights. What is your take on this and where should I start?
Thank you for your help!
Old Jan 20, 2008 | 10:26 AM
bob4x4's Avatar
Any vacuum leak of a significant size will affect all vacuum controlled accesories,they are all tied together.
Bob
Old Jan 20, 2008 | 11:51 AM
Thank you, thats the first thing Im going to check is the cruise control under the driver side battery box and make sure there is no disconected line there. I just wanted to make sure they did work together. Thank you
Old Jan 20, 2008 | 01:04 PM
JD730's Avatar
Bob
Either a big leak or it could also be a collapsed rubber connector somewhere, I just ran into that last weekend on a friends truck. No vacuum to anything down the line.
A vacuum gauge is very helpful in tracking down problems.
Old Jan 20, 2008 | 03:11 PM
mudwisr2's Avatar
I cant figure mine out either. My cruise does not work...and the "cruise" light does not come on. My 4wd does not work either but I have vacuum.
Old Jan 21, 2008 | 02:54 AM
Ed ke6bnl's Avatar
my vacuum line was rotted out at a tee that is located at the firewall on the driver side. after fixing that it worked fine. I broke mine loose wiring the fuel pressure gauge. Ed
V.R.Wheeler
Aug 4, 2007 01:00 PM
deerefarm06
Jun 4, 2007 05:54 PM
ptgarcia
Jan 4, 2007 06:14 PM
TxDiesel007
Sep 9, 2006 07:37 PM
midwestdually
Nov 29, 2004 01:33 AM
