47RE Tranny Question
Old Jun 2, 2009 | 02:13 PM
dlfrye's Avatar
Cool 47RE Tranny Question
I have a 1999 Ram 3500 5.9L diesel 4 x 4. The transmission is just about gone and I need to replace it. I do not have the money for a rebuilt unit and am therefor looking at used transmissions. My question is this...I have located a 47RE with 98,000 miles on it, but the transmission was behind a V10, not a diesel. I was told that the tranmission will work fine simply by swapping out the valve body for a valve body for a 5.9L 47RE. Is this correct? Will it work correctly? Any advice and/or suggestions will be greatly appreciated.
Old Jun 2, 2009 | 02:50 PM
mahdey's Avatar
valve body and torque convertor
Old Jun 2, 2009 | 04:45 PM
2500Ram's Avatar
How much for the used tranny? New converter is going to cost some coin as well. I had mine rebuilt at Goerend for 2600 and change. New triple disk converter, input, VB, 1 new band and a few other misc parts.
Just a thought if the used tranny is up there in price. BTW my tranny was rebuilt with 78k.
Good luck.
Old Jun 2, 2009 | 07:57 PM
dlfrye's Avatar
I assume the torque converter with my current transmission will work?
Old Jun 2, 2009 | 09:52 PM
dozer12216's Avatar
Negative - don't take a chance.
Old Jun 3, 2009 | 03:28 PM
13FOX's Avatar
VB from the v10 will be fine. However if memory serves me correctly, the TC will not work from the v10.
Old Jun 5, 2009 | 02:11 AM
glenn-k's Avatar
What makes you think it is gone?
Mine had a bad factory T/C. (Lockup clutch burned out in T/C) I adjusted the bands , put in a DTT T/C and Suncoast VB and have been driving it for about 2 years. The main trans is still original. It works fine and the truck weighs around 12000 everyday now. I am running around 300 HP.
Old Jun 5, 2009 | 03:57 AM
powermad's Avatar
my tranny started slipping in 2nd so i put a bd valve body and a bd pressure lok and drive another 20000 miles but ended up frying it when i got tired of the stock tc. if its just now strting to feal sketchy i would get it cheked out and maybe get a valve body and torque converter. but if your clutches are fried theres not much that will fix it either then tearing the tranny apart and rebuilding it. i would get a valve body at least. it made a huge difference in my old set up with a stock converter. i dont recommend getting a used tranny because its just going to go out again.
thehemikid
Feb 25, 2021 12:45 PM
Munchies
Oct 19, 2006 06:09 AM
MARKY MARK
15
Nov 29, 2005 08:36 PM
tthomass
17
Aug 7, 2005 10:00 AM
w4xtc
May 13, 2003 08:39 PM
