24v Head Injector Line Pass Throughs
Old Aug 12, 2009 | 09:11 PM
johnh's Avatar
it comes to mind that the converter lockup solenoid may have an intermittent problem
Old Aug 14, 2009 | 03:45 PM
Geico266's Avatar
Well boys & girls I figured out (or I should say Chip, at Blue Chip Diesel figured out) what the problem was on my truck. Remember I just replaced the VP44 and the problem started? I finally am picking up codes, 0602 (I think) Fueling error code. The ECM cannot communicate with the injection pump to tell it to up the RPM when I shift into drive. BAD INJECTOR PUMP! right out of the box.
Go ahead and say it Ed, I should have called Blue Chip Diesel.
Old Aug 14, 2009 | 04:51 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I'm not gonna say it................................................ ...........
Old Aug 14, 2009 | 05:06 PM
bent valves's Avatar
P0602 is a fuel calibration error that is commonly caused by the Smarty and is benign. I hope Blue Chip diesel knew that you were running the Smarty.
Old Aug 14, 2009 | 10:23 PM
dozer12216's Avatar
Think the low stall converter and extra tranny pressure could be causing the stalling.. If I understand, it starts up and idles fine till you pull into gear and rpm sags and or stalls as tranny catches the gear. So it is not getting air in lines...... I suspect the other part of your dilema has to do with different calibration of new pump. Probablly a upgrade in fueling schedule vs RPM.
try cleaning the MAP sensor, APPS reset, clean all bat cables, Throttle cable to tranny.
Old Aug 15, 2009 | 02:34 AM
Geico266's Avatar
What is it I check here?
Old Aug 15, 2009 | 10:47 AM
dieselcamp's Avatar
Thats what I am thinking, T/C is locked
king5335
26
Jan 17, 2010 07:57 PM
AAmeeting
Nov 3, 2009 11:32 PM
RockysInMyBlood
Jun 1, 2009 09:42 PM
smokin06
26
Nov 25, 2008 10:24 PM
boostedte37
13
Mar 13, 2007 01:44 AM
