24v Block ?
Old Mar 7, 2006 | 08:09 PM
tnchris's Avatar
24v Block ?
I am looking to buy my first diesel truck, and I found a guy selling a 2000 2500 Cummins. I have read about these truck possibly having the faulty #53 blocks, so I asked the guy if he could read the block #. He said he found a # and it looked like 38. Can someone varify this #? I am trying to buy a problem free truck, and this would really help me out.
Thanks,
Chris
Old Mar 7, 2006 | 08:18 PM
24valvepuller's Avatar
It should be stamped in a couple of places on the engine, mine was on the front pass. side below the oil filter and again below the injector pump on the driver side . There is some good reading here
http://www.stamey.info/Truck/Cummins...NewInformation
Old Mar 7, 2006 | 08:30 PM
tnchris's Avatar
I saw that when I was looking around. If it is not a #53 block, what would be stamped on it? I am really crossing my fingers on this one.
Old Mar 7, 2006 | 09:06 PM
Dr. Evil's Avatar
The 53 is quite big...close to an inch tall. It is hard to miss ans FYI, my block has the 53 on both sides. If you dont see the big 53 - buy it (after of course, having it scanned by a dealer and measuring the fuel pressure after the fuel filter).
BTW, Chris...there is no such thing as a "problem free" truck - theyve all got their problems and need regular maintenance - especially the 24V's. I hope youve been doing some research on the lift pump / injector pump issues.
Good Luck.
Old Mar 7, 2006 | 09:14 PM
tnchris's Avatar
I have been researching like crazy. The guy just replaced the lift pump, injector pump, and starter . I talked to him on the phone tonight and asked him if he could take a look under there and find a #. He said the only thing he could see were some small #'s that looked like 38 or 380??? I figured at least I could go look at it and check for myself. I was just curious what other block #'s there could be so I could varify something.
Old Mar 7, 2006 | 09:26 PM
Dr. Evil's Avatar
Ive never heard of a 38......Just off the top of my head theres 53's, 55's, 56's...check Chris Stameys site for more info on block numbers:
Old Mar 7, 2006 | 09:29 PM
phox_mulder's Avatar
Mine doesn't have any big numbers, just a string of little ones.
Can't remember what they are, but none of the main block numbers Evil mentioned.
phox
Old Mar 7, 2006 | 10:44 PM
displacedtexan's Avatar
I believe that means the you have the Mexican block Phox.
Old Mar 8, 2006 | 06:45 AM
skinny_9's Avatar
a dealer can check the pressure by using a scanner? instead of running a guage after the filter with somebody else's truck?
Old Mar 8, 2006 | 07:32 AM
Dr. Evil's Avatar
Say what?
Discussion is about different block castings.
To answer your question, you need a fuel pressure guage to check fue pressure. A scanner wont do it.
Old Mar 8, 2006 | 08:26 AM
HOHN's Avatar
phox
If you have large 5x series block, you have the Brazilian TUPY block. It's more common (about 8:1)
If you have just a series of smaller numbers, you have the Mexican Teksid block, which is MUY BUENO! It's a little harder and rumored to best of all ISB blocks.
Old Mar 8, 2006 | 07:49 PM
I like MUY BUENO.
phox
king5335
26
Jan 17, 2010 07:57 PM
buddy26
16
Jan 14, 2009 07:29 PM
MDLP412
Feb 4, 2008 04:35 PM
Bubspc
Jul 27, 2007 10:32 PM
24Vford
Jan 2, 2007 11:14 AM
