2002 Powr Lok
Old Nov 5, 2012 | 09:08 PM
Robert Rausch's Avatar
2002 Powr Lok
I've got a 2001.5 or 2002 Powr Lok in the rear diff of my truck. I wanted rear disc brakes in my '95 and so found a 2001.5/2002 disc rear end and swapped it into my truck several years ago. I'm thinking about replacing the clutches now and I was wondering if anyone here has done that job. Did you need to spread the case? Any tips?
Old Nov 5, 2012 | 10:07 PM
BigIron70's Avatar
Cummins Guru
I never needed to use it, I just would mark the caps then loosen the bolts. Put a wrench on the ring gear bolt rotate the powr lok until it stops turning then use a pry bar under the powr Lok and pry it out. They will usually come right out. Mark the races if you plan to reuse them, left and right side.
Old Nov 6, 2012 | 12:06 AM
Russ Roth's Avatar
I've just used a couple pry bars and they have come right out. Be careful and brace the carrier so it doesn't fall as it is pretty heavy. But you knew that already.
Old Nov 9, 2012 | 08:03 PM
Thanks Fellas! Mine needs the clutches. But it's not having any bad symptoms yet except it's not working much. Had my mechanic take a look at it a few days ago and he said spider gears are good--it just needs clutches/steels. His labor price was $385 so I guess I'll be doing them myself!
Mieser
May 27, 2009 02:28 PM
marksmith
Dec 5, 2007 07:32 AM
feveree40
Nov 7, 2007 06:44 PM
feveree40
Oct 25, 2007 02:01 PM
cditrani
Nov 11, 2005 09:20 PM
