2002 - A Few Questions
Which Boost gage, I may install an exhaust system, but
thats all the HP modes, is 30 PSI Boost enough?
How hard is it to install a pre turbo egt gage, where does
it get installed. ? When moving the lift pump
how do you reconnect the lines where the pump was?
Is there a kit to relocate the Lift Pump ?
Is the lift pump an Impeller or a shuttle type....?
Is an additional filter/water seperator a good idea,
( was common on GM ) as OEM did not trap any water??
Power Service Fuel additive ok????
****** 50 miles today , I think I'm really gonna like this
truck, If only I can find all the gears..........
If all you are going to do is add an exhaust, yes, 30 psi is ok.
I have an HO engine, so I have the HX-35W turbo, with no power adders it maxes out about 20 psi.
I'm guessing you don't have an auto because of your "finding the gears" statement, but if you do, it should have an HY-35, the 30 psi one is still fine.
Click here for some tech. info
~Rob
~Rob
missouriman
Feb 6, 2010 12:40 PM
bansh-eman
15
Sep 21, 2009 11:11 AM
GoodoleBob
Sep 27, 2006 11:37 PM
