2002 CTD wont turn over
Old Oct 8, 2009 | 07:40 AM
Palmetto_kid's Avatar
This is my FIL's truck. 2002 2500 QC 4x4 automatic
He told me that his truck wont turn over, and that he has been having to arc the solenoid to get it to start.
Tryint to fix this problem, he has had the starter solenoid rebuilt, & changed the keyswitch. Batteries are good, as well as battery connections.
I suggested to check all his connections real good, and trace the lines back to veryify everything.
Any more suggestions?
Old Oct 8, 2009 | 07:45 AM
nickg's Avatar
safety neutral switch could be faulty, thats the only component you have not listed as being repaired,
Old Oct 8, 2009 | 08:00 AM
thanks. Always having stick shifts, I have never heard of this switch. Did a search on it, and there it is!!
Where exactly is it located?
Old Oct 8, 2009 | 02:23 PM
Can someone tell me where this switch is located?
Old Oct 8, 2009 | 04:55 PM
patdaly's Avatar
Should be drivers side of the tranny, towards the middle of the valve body, sticking back thru the case.
Here is a visual, figure 2 shows it pretty well.
http://www.tciauto.com/Products/Inst...20500_inst.htm
Old Oct 9, 2009 | 10:02 AM
Thanks allot! That is what I needed to know.
Old Oct 9, 2009 | 10:13 AM
dozer12216's Avatar
Check fuse in power distrubution center box for starter relay. It frequently blows with bad soleniod.
stealman1
Nov 9, 2007 11:07 AM
qcstunter
Jan 9, 2007 04:10 PM
jiMMyCTD
May 31, 2006 08:00 AM
ktpul
Feb 13, 2006 08:01 PM
