2002 crank sensor
I just looked the one up at autozone and it says 63, provided that's the right one. Problem is that they can apparently crack and then you have to chip away at em till you get it all out of there.
On an '02 you do not have a crank position sensor, only a cam position sensor located below the VP44. You can get a replacement at any Cummins dealer (around $45). If you need to get one online, hoeslidiesel sells them at a reasonable price . BTW it's a PITA to change without removing either the VP44 or the vacuum pump; but it can be done.
92smokin blacky
Feb 28, 2011 02:36 PM
Gabe32
16
Feb 22, 2007 06:37 PM
aaronedwards82
Jan 14, 2007 09:07 AM
PaulDaisy
Dec 2, 2006 12:36 PM
