2001 starting problems
ive got a 2001 2500. i just replaced the lp and ip in the past 3 months... when the truck has been sitting for a couple hours or so, it starts right up. but, if i turn it off and try to start it within 30 or 45 minutes it cranks for a long time before starting. i can always get it to start, but somethings not right. any ideas whats goin on?
Sounds to me like you have an air leak in your lines somewhere. I would start checking for leaks in all the supply and return lines. Otherwise check your fuel pressure. My money is on a leak though.
mishkaya
mishkaya
Why would it start right up after sitting a couple hours or so and not immediately after shutdown? Sounds like something else to me, an air leak would be worse after a couple of hours rather than right after shutdown, wouldn't it?
Kurt
Kurt
i have considered an air leak but havent had time to check it out good yet... my brother told me he heard of a guy who was having a similar problem and it ended up being some kind of senor. thats all the info he knew though... i dont know much about sensors and stuff like that. has anyone else heard of something like that happening?
My 2001 was doing the same thing, started good cold, but not after shutting off for 20 minutes than try starting. I tried sensors and filters, I changed all rubber lines and put new screw style hose clamps from lift pump to main pump, starts every time now. Must have been drawing air somehwere.
I have a 03 that was very hard to start when it was cold. I took it in and had the injectors tested turned out to be that # 5 was bad so I replaced it started right up no problems until the engine got up to temp. Then hard starting again drove it back had them test while the engine was up to temp bingo #1 injector was no good when the engine was warm it passed when the engine was cold. Replaced it no problems yet
