2001" slugish when first taking off"
Old Jun 27, 2005 | 10:47 PM
OKIE1's Avatar
I have 2001 Dodge Cummins Turbo Diesel, when I first take off it seems like it's kida slugish
and also when it kicks down to a lower gear when pulling at higher rpm's.
Has anyone experence this kind of problem before?
Old Jun 28, 2005 | 02:34 PM
Saxet Nomad's Avatar
Welcome to the site...you should find a lot of usefull info here...please start off by taking the time to fill out the signature in the User CP...this helps with troubleshooting so we can see what type of truck you have and the mods you might have...
Is this something you just started noticing or has this been the way the truck has always been?
Old Jun 28, 2005 | 02:39 PM
Diesel Dave's Avatar
Did you just get the truck or have you had it for awhile and just noticed the sluggishness? If this is your first Dodge with the automatic, I would be willing to bet that what you are feeling when it downshifts is the torque converter. The stock torque converter in these trucks is noted for its inefficiency. This is why so many buy aftermarket torque converters. Then again, you could have a boost problem, lift pump problem or something else. But I would be willing to bet if the truck is new to you, it's the transmission. I would check for codes and get gauges if you don't already have them and then start saving for a transmission upgrade.
Old Jun 28, 2005 | 02:43 PM
Saxet Nomad:
Sorry that I asked the same question that you did in your post. You must type faster than me. Or you aren't as long winded as I am!
threepin73
Jul 10, 2010 04:16 PM
J_T
Jan 15, 2010 01:05 PM
smokindodge1996
Jul 12, 2009 06:24 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Dieseldude4x4
Dec 23, 2002 09:28 AM
