2001 cummins throwing a code-p1693- What is it?
Old Apr 15, 2010 | 10:20 AM
Dieseldog800's Avatar
Just replaced my lift pump and I am still getting dead pedal once in a while. What does this code mean? p1693 Did the three key cycles to get this code. Anyone help me?
Old Apr 15, 2010 | 11:57 AM
patdaly's Avatar
You need to find the companion code to the 1693, likely stored in the ECM.
Could be many things, VP44 death codes included.
Old Apr 15, 2010 | 11:46 PM
Nomad's Avatar
here's a recent one with the code
https://www.dieseltruckresource.com/...h-t268083.html
Old May 8, 2010 | 07:22 PM
rebal's Avatar
sounds like your VP pull it and have it tested
Old May 9, 2010 | 01:54 PM
Fallfork's Avatar
1693 means there is a code stored in your ECU. These trucks have several computers in them (for example ECU, PCU, and the transmission if automatic). When one controller registers a fault, the other controllers on the bus store a 1693 code, so 1693 means there is a problem on the network but it's not in this controller. If all you see is 1693, it most likely means you are reading the PCU, which has no faults stored other than the fact that another controller (probably the ecu) has a stored fault... but you can't see the code stored in the 1693. Do not panic yet... 1693 could mean ANYTHING - big or small.
Old May 9, 2010 | 09:08 PM
Junk Man's Avatar
People sure jump to unfounded conclusions and you didn't search much. 1693 is discussed much as a companion code. Also noted is the fact that pulling codes with the key doesn't always give complete information. Also discussed is the chain store tool loan program which includes a scanner. Finally, 1 of the VP rebuilders has a long detailed description on how to diagnose VP failure. They are very expensive to replace just because they MIGHT be bad.
cincydiesel
Aug 2, 2007 06:49 PM
Gunrunner
Jan 30, 2006 07:03 PM
donwon9999
27
Mar 21, 2005 06:04 PM
odie2219
Mar 3, 2005 08:55 PM
Sootman
Feb 22, 2004 07:48 PM
