2000 dodge cummins electrical problems
Old Jun 3, 2013 | 09:49 PM
banditman's Avatar
Cool 2000 dodge cummins electrical problems
When you are driving the truck the abs light will suddenly come on and the speedometer will jump back and forth anybody got any idea what is going on with this truck?
Old Jun 4, 2013 | 09:35 AM
mrclean's Avatar
Sounds like the ABS sensor in the rear diff is on its way out......
Old Jun 6, 2013 | 06:44 PM
banditman's Avatar
i have changed the abs sensor and it didnt change anything
Old Jun 6, 2013 | 09:58 PM
Mike L's Avatar
I believe that you are experiencing a classic VSS failure. Not sure where yours will be located. In my 2WD it was screwed into the rear diff, up on top.
Mike
Old Jun 6, 2013 | 10:18 PM
torquefan's Avatar
Follow the wiring from the sensor on the differential, to where it crosses over to the frame and heads forward. Have seen several harnesses get beat up by gravel where they are exposed. The wires can get torn open and corrode. Also have a close look at the terminals on the sensor connector for corrosion.
Old Jun 7, 2013 | 07:39 PM
banditman's Avatar
ok ill trace the wires and check the connectors and see where that gets me
vcswheel&tire
Jun 25, 2010 09:55 PM
poncho n' lefty
Jan 29, 2010 10:03 AM
DieselVeins
Jul 24, 2009 09:37 PM
shellman
Nov 30, 2005 07:38 PM
shellman
Nov 29, 2005 07:29 PM
