2000 24 v injector pump
Old Jul 13, 2008 | 05:35 AM
khrad's Avatar
by now most of us has had to replace the injector pump on our 2000 trucks. my question is did you have to reprogram the computor to accept the new pump? I lost about 8 mpg after the swap
Old Jul 13, 2008 | 10:53 AM
j-fox's Avatar
What is the fuel pressure.
The answer to your question is. No reprogramming required.
Is the new key in right?
Any codes?
Other symptoms?
Old Jul 14, 2008 | 07:51 AM
khrad's Avatar
no codes, tk is running great ,very little smokeItake it your talking about the key in the injector pump, I didn't think it would go but one way. and fuel pressure ????
Old Jul 14, 2008 | 12:34 PM
PaulDaisy's Avatar
Something isn't right. I replaced mine and saw the same fuel mileage. Could it be SO vs HO pump? Fill out your signature with your truck info, it helps think of possible solutions.
Old Jul 14, 2008 | 05:42 PM
johnh's Avatar
the key can be installed wrong, it is made to match the pumps timing (offset to change timing) if it is installed wrong the injection timing will be wrong...... the arrow on the key points towards the pump. you also have to use the key that came with the new pump
WesHawkins
Jul 15, 2013 11:42 PM
gablekevin
Sep 19, 2006 12:12 AM
Don Lundstrom
Jun 8, 2005 03:27 PM
CRE2004
Jan 15, 2004 11:22 PM
